Now Broken Studs
Mike Echemann
Chris:
You can always just take it down to your local machine shop and they'll take
care of it plus clean the threads and manifold for a few bucks. It's better
than messing with it if you think your at a point of harming the piece.
Sent: Monday, October 01, 2001 11:42 PM
Subject: [amphicar-lovers] Now Broken Studs
> Sorry if this is a repeat message, the other one I posted never
> showed up.
> I managed to remove the manifold, easy...
> But, I also managed to break not 1, not 2, but ALL 3 studs!
> I took the triangle flange off, and it leaves the studs sticking out
> about 1/2 inch.
> Can I torch these and twist them out with vise-grips?
> Thanks everyone who is helping!
> Chris
> '63 Red (feeling a draft) "Chaos"
> To UNSUBSCRIBE from this group, just send an email TO THE FOLLOWING
ADDRESS (this is not the same address for posting messages):
> Any other issues may be addressed to the list owner/admin (Mike Israel)
showed up.
about 1/2 inch.
Chris
<font FACE="arial,helvetica"><font SIZE="2">Heat the manifold with torch until the manifold is red do not use a cutting torch use the smaller flame as if you were brazing something.
T. Wick</font>
Re: Re: Now Broken Studs
<font FACE="arial,helvetica"><font SIZE="2">Machine shop should have no problem good luck</font>
I used a standard propane blow-torch but after 15 minutes I could
not heat the metal to a point where it was even close to red. (of
course the temp was 45 degrees in the garage this morning)
I am calling a machine shop today and taking manifold over to have
them do it. Should be a walk in the park for a pro. :)
Chris
cutting
> T. Wick
Chris,
I'm trying to send you a private email but it keeps being bounced back as
undeliverable. Please contact me.
Ken Chambers, CA
'64 Amphi
> From: chris_skeeles@yahoo.com
> Subject: Now Broken Studs
> Warning: this message contains an abused "Star Trek" reference.
> Ok..
> I managed to remove the manifold. Yes, I agree, its much easier to
> work on the pipe flange studs. And easier to break them.
> I managed to break ALL 3 flange studs!
> (damit Jim, I'm a CEO, not a mechanic)
> So, I have manifold with 3 broken studs sticking out about 1/2 inch.
> Do I put the torch on these studs then turn with vise-grips or do I
> have them tapped out? :(
L
Replies
1
Views
726
David Derer
Replies
Views
757
Moses Scott Con 22 LG
G
Replies
2
Views
840
dougn200
