L
Larry & Nancy Solheim
In the "It's Always Something Department" . . . . . Now that the engine/clutch workare complete, looking at other things I noticed that the port side prop shaft bearings are quite noisy. Now seems the time to work on it as everything else is out of the way. Has anyone removed/replaced shaft and bearings with the housing assembly in the car? I did the replacement work on MetalBeast (many years ago) on the bench per the manual,andrecall using a brass drift and hammer to remove the shaft (per manual) and not a press. Therefore, I see no reason why it wouldn't work. Just thought I'd get some "voices of experience". I also seem to recall not properly rotating the shaft during the disassembly and bending spacer washers that needed to be repurchased, but I can't quite remember the exact problem. Thanks, --Larry (& Amphi in drydock)
<hr size="1">Relax. Yahoo! Mail virus scanning helps detect nasty viruses!
