Reply-to: goob
Subject: Re: [amphicar-lovers] Polarizing a new generator
I don't think you want to polarize your generator, your voltage regulator would
be a better candidate for this. Look in the local Yellow Pages and save a lot of
money, pay a professional! That's what I do, and I've been around Amphicars
since 1965.
Received: from n2.groups.yahoo.com (n2.groups.yahoo.com [216.115.96.52]) by
swns.net (8.8.5/8.8.3) with SMTP id WAA06153 for <goob@swns.net>; Mon, 20 Aug
2001 22:18:51 -0400 (EDT)
X-eGroups-Return:
sentto-2090616-2664-998360132-goob=swns.net@returns.onelist.com
Received: from [10.1.4.55] by hi.egroups.com with NNFMP; 21 Aug 2001 02:15:32
-0000
X-Sender: markr13@prodigy.net
X-Apparently-To: amphicar-lovers@yahoogroups.com
Received: (EGP: mail-7_3_1); 21 Aug 2001 02:15:31 -0000
Received: (qmail 93964 invoked from network); 21 Aug 2001 02:15:03 -0000
Received: from unknown (10.1.10.26)
by l9.egroups.com with QMQP; 21 Aug 2001 02:15:03 -0000
Received: from unknown (HELO pimout1-int.prodigy.net) (207.115.63.77)
by mta1 with SMTP; 21 Aug 2001 02:15:03 -0000
Received: from pavilion (A010-0046.KNVL.splitrock.net [209.255.8.46])
by pimout1-int.prodigy.net (8.11.0/8.11.0) with SMTP id f7L2ExZ191968
for <amphicar-lovers@yahoogroups.com>; Mon, 20 Aug 2001 22:14:59 -0400
Message-ID: <002401c129e6$0cc77660$2e08ffd1@pavilion>
References: <998301170.287.390.l10@yahoogroups.com>
Organization: Prodigy Internet
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 5.00.2615.200
X-Mimeole: Produced By Microsoft MimeOLE V5.00.2615.200
MIME-Version: 1.0
Mailing-List: list amphicar-lovers@yahoogroups.com; contact
amphicar-lovers-owner@yahoogroups.com
Delivered-To: mailing list amphicar-lovers@yahoogroups.com
Precedence: bulk
List-Unsubscribe: <mailto:amphicar-lovers-unsubscribe@yahoogroups.com>
Date: Mon, 20 Aug 2001 22:07:32 -0400
Reply-To: amphicar-lovers@yahoogroups.com
Subject: [amphicar-lovers] Polarizing a new generator
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
X-UIDL: dd566bbfdd4f344a8e5e1c76da87f481
Status: RO
Anybody out there know how to polarize a new generator. I have one installed
& blue light is on & gas gauge will not work. I know it is easy, but do not
want to blow up the new unit. Thanks, Mark
Sent: Monday, August 20, 2001 5:52 AM
Subject: [amphicar-lovers] Digest Number 380
> There are 6 messages in this issue.
> Topics in this digest:
> 1. RE: [water leaks)
> From: "Gord Souter" <houseboats@encode.com>
> 2. checking for leaks
> From: Arnold Hite <ahite@Charleston.Net>
> 3. Unsubscribe m5076@interlynx.net from group
> From: "Mike" <m5076@interlynx.net>
> 4. Re: RE: [water leaks)
> From: pfgbrian@aol.com
> 5. Re: coins
> From: miabumpa@aol.com
> 6. Two Piece Metal Generator Fan/Pulley
> From: Allan Woodcock <awoodc@earthlink.net>
> ________________________________________________________________________
> Message: 1
> Date: Sun, 19 Aug 2001 06:49:44 -0400
> Subject: RE: [water leaks)
> Message: 4
> Date: Sat, 18 Aug 2001 14:58:52 EDT
> Subject: Water in the bilge
> Hello, I have a freshly restored Ampi. Went in and out of the water twice,
> and a total of maybe 5 minutes swimming. Got home, and found @ 1/2 gallon
in
> the bilge at the rear. Water was below drain plug level, and below bilge
> pump
> level (I used a wet vac to get out). A little dampness in the hood aea,
but
> not enough to have gone down drain tube. Could it have entered rear engine
> cover vents-I went pretty slow going in- maybe 10mph. What is normal on a
> fresh resto with new everything? Areas to check? Love our new car, but
just
> trying to learn as I can! Thanks! Brian in CA
> The best way to check water leaks is to take your rear seat out,remove
> undere seat cover,
> take main seat out(6 screws)and remove floor boards.put in a small piece
of
> plywood and a crate to sit on.Open engine lid.
> now go in the water very carfully and look for leaks.
> Main places to look for small leaks are;
> emergency brake cables
> rear axle bellow(this could be a big leek)
> body seams
> door seals(will come in at rear of door 6 inchs down threw opening.)
> front steering bellows
> tube to front trunk(could have hole in top of tube from wear of steering
arm
> touching it)
> if water is coming from front tube could befront bumper bolts,park lites
or
> head lites.
> look in engine compartment ,could be rear bumper bolts,rear trim between
> bumpers,
> drain plug.or body seams.
> My final test proved to be in the engine compartment.the water seamed to
be
> steaming in form under the battery(l have the original box)
> This is where a brace bracket is welded on the car.On final exam on hoist
l
> found the seam had opened up letting water in the side fender cavity and
> when it filled it overfowed out under the batery. small amount of seam
> filler solved the problem.
> I have install a glass floor()lexan)in my car(got the idea from Dave Molen
> in Florida)
> and can keep a very close watch fo leaks at anytime now.
> I may have some good news for northern clum members in Oct, more on that
> later.
> 1st Amphicar criuse in was a flop as far as cars showing(only jeff and me)
> two other oweners showed up with out there cars , we had a good talk and
> lots of rides in cojuntion with the boat show.
> Over 320 show cars and rods lined the main street of Orillia.good 50s
dance
> etc.
> GORD SOUTER 62 white
> ORILLIA ONT>
> Message: 2
> Date: Sun, 19 Aug 2001 08:48:00 -0300
> Subject: checking for leaks
> Brian,
> I doubt water is coming in around the engine vents. I get a little
> water at the front hood seal but not enough to worry about much. The best
> way to tell where the water is coming from is to remove the rear seat and
> watch while you put the car in the water. The leak will probably be
> obvious, but even if you can't see the leak directly, you will see the
> direction water is flowing from. Other club members will suggest putting
a
> hose in the car while on land with plug in and checking for leaks
> underneath. I haven't found this as helpful but it is less trouble than
> removing the seat and driving to a ramp.
> Arnold Hite
> Johns Island, SC
> > Message: 4
twice,
gallon
> in
> pump
> but
engine
a
> just
> Message: 3
> Date: Sun, 19 Aug 2001 09:55:10 -0400
> Subject: Unsubscribe m5076@interlynx.net from group
> I have noticed there are constantly members asking to be removed from you
list.
> I have personally tried to do this 4 times, following your directions
exactly, but still I receive e-mails.
> Instead of trying to be a smart ass by suggesting we use duct tape on our
computers, maybe you should perfect your own e-mail system.
> Dr. Michael Smith
> [This message contained attachments]
> Message: 4
> Date: Sun, 19 Aug 2001 12:29:51 EDT
> Subject: Re: RE: [water leaks)
> Thanks for the input. We think most of the leaks are coming from under the
> hood area-lights, steering seal, bumber brackets, etc. Went out again for
20
> minutes and picked up @ 3+ gallons.
> In regards to the new floor, how thick do you recommend for the lexan. I
> wouldn't mind spending the money on that-is a great idea!!!
> Thanks!
> Brian in CA
> Message: 5
> Date: Sun, 19 Aug 2001 12:58:16 EDT
> Subject: Re: coins
> scott have not recived info for ordering coin please e-mail to me at
> miabumpa@aol.com so i can send $ thanks jay plum 67
> Message: 6
> Date: Sun, 19 Aug 2001 15:27:04 -0700
> Subject: Two Piece Metal Generator Fan/Pulley
> I have rounded up a few of these generator fan/pulley sets. They are
> cleaned and painted and they are used. I have removed tham from Truimph
> generators. The price is $45. Hugh has no pulleys and only a few fans.
> He won't sell the fans he has. The part number at Gordon's is
> 1-09-04b. I have posted photo's on my Ampicarbumpers.com page so anyone
> interested should take a look and see which of the two styles they
> want. I have two 67 'Amphi's and they each have a different generator
> in that the fan spacing from the generator housing is not the same.
> e-mail: awoodc@earthlink.net.
> Allan Woodcock
