mytwocentsworth
wick68355@aol.com
On door seals. I would think you would be better off with both seals
installed as was original. Just the idea of the rubber against the steel does
not seem as secure as rubber to rubber.
On bleeding brakes. I like to bleed the brakes on our Amphi every season.
This just gives me a piece of mind knowing that I have done what I can to
keep the fluid free of dirt and water. I have tried a pressure bleeder and
have not had much luck. I have also tried a Mighty Vac bleeder. This just
does not seem to work either. I believe it does not work because of the
valveing in the master. My best luck has been simply be following the large
shop manual which came with the Amphicar. All that I do is open one bleeder
at a time and then push the peddle down, here is where it gets weird. Let the
peddle up then close the bleeder. Do not pump the peddle. Start at the
farthest wheel and work towards the closest to the master.
Also for you first time or new Amphi owners, replace the small hose that is
attached to the bottom of the plastic reservoir. It has a tendency to
collapse and not let fluid out.
On positive ground generators. I have kept our Amphi positive ground only
because of my desire to keep as many things original as possible. My one
modification to the charging system is the addition of an extra positive
ground cable running from the stud on the body to the engine block. This just
helps the engine block get a direct ground.
My long two cents worth
Tim Wick
hibernating in Wisconsin
buoyant3 <martyandcaryl@charter.net>
Tim
How's it going? I need to do a brake job and want to learn anything
special B4 I start. I don't understand the part in your bleeding
where you let the peddle up then close the bleeder. I have always
closed the bleeder B4 letting the peddle up. What gives?
Marty
BUOYANT in WI
Looking for a little more snow tonight.
seals
steel does
season.
can to
bleeder and
This just
the
the large
one bleeder
weird. Let the
the
that is
to
ground only
My one
positive
This just
> Tim Wick
Michael Echemann
Re: Re: mytwocentsworth
Tim:
Be sure and rebuild your master cyl. also. You've got the right idea, push the
pedal, close the bleeder and then release the pedal. Start with the rear right,
rear left, front right then front left. Can't miss.
Sent: Thursday, January 30, 2003 7:49 AM
Subject: [amphicar-lovers] Re: mytwocentsworth
Tim
Marty
BUOYANT in WI
seals
steel does
season.
can to
bleeder and
This just
the
the large
one bleeder
weird. Let the
the
that is
to
ground only
My one
positive
This just
> Tim Wick
THE AMPHICAR-LOVERS LIST
G
Gary Grieshaber
Hi,
This method of brake bleeding involves attaching a rubber hose to the
bleeder and placing the other end in a container(e.g. glass Coke
bottle) partially filled with CLEAN brake fluid. Open the bleeder, push
the pedal, air(if there is any)will escape thru the hose into the
bottle and when the pedal is released only fluid will return to the
bleeder! Or, have a friend come over for a beer, and a brake fluid
covered forearm.
Gary.
> Tim
> Marty
> BUOYANT in WI
> seals
> steel does
> season.
> can to
> bleeder and
> This just
> the
> the large
> one bleeder
> weird. Let the
> the
> that is
> to
> ground only
> My one
> positive
> This just
> > Tim Wick
> Archives:
> visit:
NeoMail - Webmail that doesn't suck... as much.
http://neomail.sourceforge.net
