Re: Re: Motor Pull
Withthe engine "frozen" as tight as you describe, it's
possible that some corrosion has locked the
transmission shaft splines to the flywheel. I also
recommend pulling the bellhousing with the motor. It
is fairly easy, using a screwdriver, to lightly pry
the square end of the bellhousing away from the
transmision at all four bolt locations. I have taken
both xmission and engine together (although then you
have to pull the rear axle assys) to separate on the
floor or a stand -- if so it's helpful to raise the
rear of the Amphicar slightly to improve the
extraction angle.
From past experience, you'll probably find the bearing
OK, but the rings stuck in the piston grooves, against
the cylinder walls.
Good luck!
--LarryS
--- John <isettajohn@aol.com> wrote:
> --- In amphicar-lovers@y..., tommyintpa@a... wrote:
> > Hi, I just pulled the motor out of Weird Harold
> last Thursday. I
> left the bell housing attached to the motor so I
> only removed the
> four bolts that hold transmission to the bell
> housing. You may have
> forgotten to remove the starter, that will hold the
> block to the
> transmission. You also need to remove the bracket
> that is bolted to
> the motor mounts, you can't get the motor out over
> it.
> Both items were removed. I have been working on
> cars for 35
> years so this isn't my first motor job, just the
> first Amphi. Thats
> why I'm a little baffled why it won't come out. I
> will try leaving
> the bell housing as you did and take the 4 trans
> bolts out now.
> (Fingers crossed) JW
Do you Yahoo!?
Faith Hill - Exclusive Performances, Videos & More
http://faith.yahoo.com
