Motor out!
  • Thread starter Thread starter gtpeterp
G
gtpeterp
After much struggling and cursing, the motor is out.
http://www.pociask.com/amphicar/amphi_engine_pull/
(My roomate was running the camera, so her dog shows up in there too)
It actually wasnt that bad, once we got the fan off of the engine. We
found several old sockets in the bilge, as well as a couple of
maintenance items (The bell housing was only held on by three bolts,
numerous bolts were only finger tight, including the engine fan).
We also ran across one mystery part. Theres a tube off of the drivers
side of the engine that doesnt appear to do anything.
http://www.pociask.com/amphicar/amphi_engine_pull/imagepages/image24.html
Just past the dipstick, goes up and then back down at a steep angle.
Ideas?
Also, I lack bolts long enough to attach the egnine to my stand, so
its sitting on the hoist for the evening. Does anyone know the proper
thread off the top of their head?
Finally, what is the official number on the weight of the engine? I
couldn't find anything on google or in the archives...
Thanks for all of the advice, could not have done it without you.
Peter
Hi: I think that 'tube' is a block vapor vent. Pre-pvc cars had them. Regular cars called them 'road draft' pipes. They were in the air stream and the oil vapors were sucked by vacuum (MPH) and did a nice job of keeping the bottom of the car oiled. Marc.
<table bgColor="#ffffff">
<tt>> Just past the dipstick, goes up and then back down at a steep angle.
> Ideas?
</tt>
<tt>Crankcase vent pipe, it prevents pressure buildup caused by pistons going up and down. Your car being American spec had a basic emmission system so the pipe is crimped closed,a non vented cap is fitted to oil filler and a tube from valve cover to air filter, idea is fumes get drawn into engine through air intake and burnt. It sort of worked... Later engines had the vent pipe removed and a blanking plug fitted to block.</tt>
<tt></tt>
<tt>Dont be tempted to use the crackcase vent as a handle, it lifts about half the engine weight before it pulls out of the block ! </tt>
<tt></tt>
<tt>Be sure to check the core / freeze plugs carefully and that red water hose looks wrong - check it is adequate quality. </tt>
<tt></tt>
<tt>Weight varied a lot depending on what is on engine and even between engines - the oil adds 5% - but work on 100Kg and you won't be faroff.</tt>
<tt></tt>
<tt>Engine bolts are a real mixture, most are UNF thread, some like the manifold are UNC, a couple are a very old thread called Whitworth and of course the Amphi related ones are metric. Be careful if using the engine back plate to bolt to stand, it isn't really strong enough and can bend. </tt>
<tt></tt>
<tt>David C</tt>
> > Ideas?
system so the pipe is crimped closed, a non vented cap is fitted to
fitted to block.
engines - the oil adds 5% - but work on 100Kg and you won't be far off.
can bend.
> David C
Ahh. That makes sense. I'm planning on stripping most everything off
of the engine and replacing it with known good parts. I may see about
removing the pipe and getting the plug, just to free up some space.
How would you reccomend I mount it on the engine stand? I was planning
on just using the bell housing bolts...
Peter
