Motor Oil For Flat Tappet Engines
awoodc
Our 1960's engines with flat tappets and solid lifters are probably not getting proper lubrication with today's motor oils. The reason is that zinc and phosphorus levels have been drastically reduced because they can foul catalytic converters. These chemicals formerly acted as a "cushion" between moving parts. I was at a speed shop near the Pomona Raceway last week and the owner told me that he has seen an increase in 1960's cars losing their cams due to premature wear.
You are welcome to look at ebay item 150539503774 to see if you want to start using oil with the correct amounts of ZDDP.
Let's have some comments - good or bad!
Allan
'66 red
Amphicar Forum Admin
Staff member
The zddp issue is certainly a very real concern for older engines.
I have never heard of the Fisher brand of oil?? Valvoline's VR1 is a high quality standard oil that is 1300 ppm zddp and is available at most auto parts stores. If you prefer Synthetic I believe both amsoil and Redline offer zddp enhanced oils and I am sure the exact specs are available.
Lots of good info on the web including::
http://www.ttalk.info/Zddp.htm
bkahler
Allan,
Brad Penn sells very good oil for these engines. We use the 30w Brad Penn
break-in oil for new engines and their 20w50 oil after break in. The oil is
blended for flat tappet engines. Been using it in Susan's Spitfire race
engine (1300) for several years and we're quite happy with it.
Brad
> Allan
> '66 red
S
SplitPersonality
Regarding the ZDDP subject in the formulation of motor oil, Amsoil now has
a product with Zinc in the formulation. I do not know if this corresponds
to the ZDDP requirement or not. Bilgey - can you enlighten us on this
matter ? Vic Nelson with the "Split Personality"
In a message dated 12/26/2010 5:37:29 P.M. Eastern Standard Time,
writes:
Allan
'66 red
S
SplitPersonality
It is quite certain that the ZDDP subject is important, but it is hard to
know how much credibility to put on an e-mail without any signature to
provide the reader with some knowledge of the sender's experience and
knowledge. Knowing who provides the information or advice gives one some chance of
assessing how worthwhile the information may be. Victor Nelson
In a message dated 12/26/2010 8:02:29 P.M. Eastern Standard Time,
writes:
_http://www.ttalk.info/Zddp.htm_ (http://www.ttalk.info/Zddp.htm)
mike_israel Blackstone Labs Motor Oil Report General Amphicar Discussion 0
Jon March do new motor & tranny mounts affect motor height/fan shroud alignment? General Amphicar Discussion 11
Jon March is there a thread on steps to remove motor? - unsure how to unbolt, bolt locations, etc... General Amphicar Discussion 0
SNOWBIRD Motor Pull ? General Amphicar Discussion 1
D windshield wiper motor bench test General Amphicar Discussion 3
S Wiper Motor General Amphicar Discussion 3
sdreich Starter Motor Installation: A Two-person Job? General Amphicar Discussion 1
S Blower Housing Motor & Mount General Amphicar Discussion 0
B Best Motor Oil for Amphicar General Amphicar Discussion 6
A Amphicar at Lowes Motor Speedway General Amphicar Discussion 0
G Motor out! General Amphicar Discussion 3
J MOTOR PARTS QUESTION - POSTED FOR ROB VONDRACEK General Amphicar Discussion 0
R 1296 motor General Amphicar Discussion 0
R 1147 motor General Amphicar Discussion 0
R motor and tranny General Amphicar Discussion 1
R motor General Amphicar Discussion 0
M Amphibious Motor Home General Amphicar Discussion 1
L Inside the Wiper Motor: Contacts General Amphicar Discussion 1
L Wiper Motor Grease Question General Amphicar Discussion 1
E Windshield Wiper Motor Removal General Amphicar Discussion 1
B Searching for motor mounts General Amphicar Discussion 3
T wiper motor General Amphicar Discussion 1
W Motor Pull General Amphicar Discussion 6
A Wiper motor question General Amphicar Discussion 1
T Engine cut out and blower motor General Amphicar Discussion 3
D motor mounts General Amphicar Discussion 0
J Motor Swap General Amphicar Discussion 2
O An invitation to owners of "Unique Motor Vehicles" General Amphicar Discussion 0
A Charlotte Motor Speedway Auto Show General Amphicar Discussion 0
A Charollete Motor Speedway Auto Show General Amphicar Discussion 0
D Amphibious Motor Home on Ebay ... General Amphicar Discussion 0
Akamphi Flat towing an Amphicar General Amphicar Discussion 13
Akamphi Flat towing photos General Amphicar Discussion 0
Midwest Amphicar Flat quarter repair General Amphicar Discussion 1
