motor mounts
dougn200
Arnold,
an alternative to chankging the mounts until you are ready is to put
hose clamps around them and tighten them down. But if you do change
them out and when you put your shroud back on make sure to check for
fan clearance as it usally changes on the new mounts that Hugh sells
and also you will probably have to drill a bit bigger hole on the
bracket to get hughs in. The wat to tell if you have a good
adjustment on these is you oil drain plug should be in the center of
the bilge plug hole.
And if you wait on changing them make sure you have an extra
generator pulley as I still believe that this has something to do
with them exploding.
Merry christmas... Happy Holidays...
and as tiny tim says'
God bless us all every one
Doug and Phyllis
