Missing - Coil Temp?
amphi662001
After swimming about 45 minutes Amphi's 4-banger suddenly became a 2-
banger. No overheating of the coolent. We limped to the ramp (w/
extreme "putting" all of the way, but lacked power to pull out. About
the the time a friend came w/ a line to haul us out, Amphi started and
ran fine. We pulled out and drove home. The smell of unburnt fuel and
a backfire leads me to believe it is electrical, not fuel related.
Subsequently, an hour at fast idle has not duplicated the problem.
I am replacing those items dedicated to individual cylinders (cap,
rotor, plug wires and plugs), but that still leaves the coil and
Pertronix module. I would think failure in these areas would not cause
the 2-cylinder symptom, . . . . but . . .?
The positive-ground, 41-year old coil gets too hot to touch for any
length of time, but I understand that is normal. Any ideas?
--Larry
<font face="Arial" size="2">What leads and cap do you have ? The modern type non copper core leads fitted to the side entry cap willeventuallyburn backand cause this.</font>
<font face="Arial" size="2">If the rotor arm is LESS then15 years old then change it. Originals are mostly good forever but new ones aren't.</font>
<font face="Arial" size="2">Yes, coils can and do fail, I'd swop them at least once a decade ! They get hot but not too hot to touch. </font>
rlgreen_55
Take a ohm reading on the coil low voltage terminals. You should be
reading between 3 1/2 & 5 1/2 ohms.
Ron Green
--- In amphicar-lovers@yahoogroups.com, "amphi662001"
2-
About
and
and
cause
> Thanks,
> --Larry
