Max RPM - 1200 Vs. 1500 engine
rogtwo@aol.com
While trying to find torque information for Triumph engines, I found this web
site:
http://www.totallytriumph.net/
At it I found some information about the 1147 and 1500 engines that I thought
was interesting.
Form this page, I found the following:
http://www.totallytriumph.net/spitfire/engine_building.shtml
"The 1147 & 1300s can all rev much higher* than a 1500, the 1500 due to its
bigger capacity has more low down pulling Torque."
"The 1500 is a low revving, high Torque engine. In a fully stock motor avoid
revs above 5500.
A prepared engine, balanced with stronger rod bolts can be safe to 6000 Rpm.
Still, remember that its not an engine for thrashing at high Rpm."
* This web site recommends, for an engine in stock form, a maximum RPM of
6000 for the 1147 & 1300 and 5500 RPM for the 1500. I think the "much higher"
comment was meant for race engines, where there is a larger difference.
Further, on this page drivers voted for what they thought the maximum
sustained speed should be for the 1500 engine. Of the 20 people that voted,
they all
thought that the 1500 engine should not be run at a sustained speed over 4800
RPM (70 mph in an Amphi). Many weren't welling to run them this fast.
http://www.totallytriumph.net/dcforum/DCForumID7/148.shtml
I have no personal experience with or knowledge of the 1500 engine, I am just
passing along the information from this web site.
Roger
White '63
Seattle
L
lah20car@aol.com
Hi everyone, since this engine thingy is up again--I have two of these
Spitfire engines mostly because they were in my backyard and at one time had
thought
of putting one in my car but now want to get rid of them for what they cost
me--$400 each. Both were running and one a recent rebuild, both are complete,
intake, exhaust and transmissions. Only thing is-- I won't get involved in
shipping these, but will deliver to New Orleans or Dallas or Houston for a small
cost. If you are interested or want pictures contact me offline before I put
them on Ebay--Thanks--and remember winter only last for a little while-- at
least here--Ken
Hi Ken,
What size are these engines 1147's, 1296's or 1500's?
these
time had thought
they cost
complete,
involved in
Houston for a small
before I put
while-- at
> least here--Ken
The reason you don't want to over rev a 1500 is because they are a
stroked 1300. The pistons travel furter in the same amount of time
each rev and therefore are moving faster. If the piston speed is too
fast, it will eventually disentegrate the piston(s) every time. For
this reason, the 1500 is not a good choice in an Amphi.
RMA
Re: Re: Max RPM - 1200 Vs. 1500 engine
RMA
True, but the issue with the 1500 and some 1300s is they have a much larger
crank, introduced at the British Leyland factory around 1970 for
standardisation reasons (ie to save money) so they can never be as smooth
because of all that reciprocating mass. A 1500 will be quicker away from the
lights than an 1147 but top speed will be higher with the smaller engine and
it will be much smoother, quieter and cooler at the normal water cruising
speed of about 2200rpm.
David C
much larger
smooth
away from the
engine and
cruising
Thanks David, that is a new piece of info I did not know about. The
rotating mass makes perfect sense with reguard to how they will
react differently. What other significant differences are there
between the 2? - JB
Akamphi Spit 1500 engine break in. General Amphicar Discussion 1
BuckeyeFloater 1500 Again General Amphicar Discussion 2
C 1500 conversion question General Amphicar Discussion 11
C 1500 conversion General Amphicar Discussion 7
SNOWBIRD Engine surprise General Amphicar Discussion 1
D Engine Draft Tube General Amphicar Discussion 3
Jon March Proper engine break-in General Amphicar Discussion 4
mike_israel 2-ton engine hoist for $143 General Amphicar Discussion 0
Jon March Engine compartment - !@# manual scraping. stripping, degreasing, sanding, priming, painting General Amphicar Discussion 6
P cautionary tale (my engine upgrade experience) General Amphicar Discussion 14
okey0 Engine OUT....how to mount on stand now? General Amphicar Discussion 9
Akamphi Engine oil priming tool General Amphicar Discussion 3
Ken Chambers Entertaining engine rebuild General Amphicar Discussion 0
AHite Possible Engine Conversion General Amphicar Discussion 8
S Pulling an engine General Amphicar Discussion 7
A engine timing and dwell General Amphicar Discussion 3
Midwest Amphicar Engines engines who needs an engine General Amphicar Discussion 4
azpaul50 Engine Cover Luggage rack General Amphicar Discussion 6
Midwest Amphicar Engine cover holes or how I spent today General Amphicar Discussion 1
B Re: Engine cooling fan General Amphicar Discussion 0
B engine cooling fan General Amphicar Discussion 2
amphicarian Engine advice General Amphicar Discussion 19
DavidC Amphicar engine in Alabama General Amphicar Discussion 0
A engine milage and mechnical status General Amphicar Discussion 7
K Engine compartment paint. General Amphicar Discussion 2
W engine and transmision General Amphicar Discussion 4
C engine rebuild General Amphicar Discussion 1
C Underside hull paint and engine compartment paint General Amphicar Discussion 6
W engine manifold mystery General Amphicar Discussion 7
B SV: SV: Re: Engine cooling / Fan noise General Amphicar Discussion 0
B SV: Re: Engine cooling / Fan noise General Amphicar Discussion 1
D engine personalities General Amphicar Discussion 1
W Engine cooling / Fan noise General Amphicar Discussion 6
B 1147 cc engine advice needed General Amphicar Discussion 2
J Harley engine ---Lake Ozarks next week General Amphicar Discussion 1
B Engine Dies When Hot General Amphicar Discussion 9
