All this talk about a "magneto" valve has bothered me a bit, because it fuzzes
the accuracy of what the valve is and does. A magneto valve should either
control a magneto, or be controlled by a magneto. The Amphi valve should be
called an electrically operated fuel valve, since it controls fuel flow, and is
operated by application of the 12 VDC vehicle power. I'll even accept calling it
a fuel cut-off valve. An Amphi doesn't have a magneto; it uses the very common
Kettering ignition system (cam actuated breaker points and a step-up HV coil).
The valve should be turned on (12 VDC applied to the control coil) whenever you
expect to run the engine, so the coil should be fed from the "RUN" contact on
the ignition switch. Maximum safety suggests you put the valve as close to the
fuel tank as possible. I am planning a major modification of my fuel tank; I'm
going to eliminate the bottom-fed fuel tap & fuel selector switch (with all it's
inherent leak problems), and permanently seal the bottom tank hole. I am then
installing a top-of-tank fuel port, and I will mount an electric fuel valve
there.
There's no magic in selecting a fuel valve; the Amphi sips fuel so slowly that a
valve OK for anything automotive will work for an Amphi.
Sent: Wednesday, February 12, 2003 3:15 AM
Subject: Re: [amphicar-lovers] Digest Number 909
In a message dated 2/11/2003 3:36:05 AM Eastern Standard Time,
amphicar-lovers@yahoogroups.com writes:
> It is intended to inhibit the possibility of fuel
> "siphoning" down the fuel lines from the gas tank and pouring out the carb
> when the vehicle was parked, especially if on an incline when the fuel
> level
> in the tank is higher than the carb.
I don't have any valves (last owner removed them becaus eof leaks, and my car
has never siphoned any fuel out when parked, but I would feel safer with a
tap. Can anyone suggest an inline magneto valve that can be installed at an
easier accessable location than under the tank?
Chas
THE AMPHICAR-LOVERS LIST
there.
> level
Chas
