Looking for Carburetor rebuild kit
Tedredamphi
:032:I am looking for a carburetor rebuild kit for what I believe to be my Amphicar carburetor. Amphicar came with no carb installed but a box of 5 carbs of various manufactures. The one I believe to be correct is a Solex 30PSEI with a stamping of LC81 (very faint and not sure of this number) on the side. Dissassembled the carburetor and it looks to be in pretty good shape, just needing a rebuild.
So where can I find a rebuild kit for this thing???
Ted Matthews
Texas
jwillia
Gordons had them at one time check there. I may have a spare but not home now.
jeff Alaska
To: jeffreyd_7@hotmail.com
Subject: [General Amphicar Discussion-t-20423] Looking for Carburetor rebuild kit
Date: Sun, 17 May 2009 21:35:51 -0400
Ted Matthews
Texas
Bilgemaster
Sorry that I've got no rebuild kit for you, but I'm pretty sure that
Hugh Gordon must still offer one. The real reason that I'm piping in
here is to tell you that the 'Members Only' area of the club website
should still have a copy of the entire Solex manual in PDF format titled
"Solex: Selection and Tuning of the Carburetor." And in case you're not
yet a member (Ummm...Why not? You some kind of
maverick-gotta-do-it-the-hard-way type?), a google search of the full
title should coax up another copy of it out there somewhere.
Regards,
Bilgey
> home now.
> jeff Alaska
> rebuild kit
> From:
> Thanks,
> Ted Matthews
> Texas
Tedredamphi
Just found the carburetor rebuild kit in the Gordon Imports catalog. Just hope that they have some in stock. Thanks for the info in the Solex Tuning Guide in the members only section. And yes Bilgey, I am a member.
Ted
Canadian four amphs
I carry every bit and piece for rebuilding Amphicar carbs, even the tiny return springs on the choke butterfly.
I have 100s of middle gaskets and have made a bunch of general kits up,there not listed in my parts book but,are $45.00
parts 07-5 to 07-58 are on my sheet of parts
GORD SOUTER>
awoodc
body{font-family: Geneva,Arial,Helvetica,sans-serif;font-size:9pt;background-color: #ffffff;color: black;}
Ted, I have 'em. Email me: amphicarparts@earthlink.net
Allan-----Original Message-----
Sent: May 17, 2009 10:25 PM
To: awoodc@earthlink.net
Subject: RE: [General Amphicar Discussion-t-20423] Looking for Carburetor rebuild kit
jeff Alaska
Ted Matthews
Texas
Hi ted; Did you try kip motor parts in dallas? I think I got one there along with generator and starter etc. kipmotor.com Amphigreen.
--- On Mon, 5/18/09, awoodc <> wrote:
> From: awoodc <>
> To: mstrug1959@att.net
> Date: Monday, May 18, 2009, 11:24 PM
> body{font-family:
> From: jwillia
> jeff Alaska
> From:
> believe to be
> installed but a box
> correct is
> sure of this
> looks to be in
> Thanks,
> Ted Matthews
> Texas
Bilgemaster
Assuming the carb's all there, maybe it's pretty much OK or at least
serviceable, and for at least the time being you could get away with a
trick my Dad told me they used to work when he was a mechanic in the
Army in the '50s in France, often reviving old WWII Jeeps,
Deuce-and-a-halfs and even DUKWs that had been mothballed since VE Day:
When the carbs were clogged up with lead and other deposits, they used
to pull them off, shake out the acorns and just toss them into a small
barrel filled with Marvel Mystery Oil to "marinate." After a good long
soak they would haul them out, slap them on and presto!
I did that with my old Norton's super-simple Amal Concentric carb that
looked like the inside of one of the Luray Caverns when I got it as a
"basket case," and it spritzed along just fine after I got the rest of
the plot screwed back together (with an oil supply-return system poached
from a Lady Kenmore washing machine and other make-do scavengings of the
"Max Max" sort).
Regards,
Bilgey
On Tue, 19 May 2009 12:28 am, Tedredamphi wrote:
> Gordon Imports has them on back order!!!!
> Ted
Steve
GORD SOUTER>
Gord, do you still have any of these kits? I'm looking for one.
