Line X linner
watercar64
I have a few small rust holes in the bottom
of my Amphicar , And was looking into this
Line X spray on truck Linner , it is flixable
and waterproff. looks like a good product.
Has anyone tried this on the bottom of ther amphi?
It should hold up , would like to have some
respounce to this .
Thank you
ross.donald@netzero.com
WB6WSN
Sent: Friday, January 30, 2004 8:18 PM
Subject: [amphicar-lovers] Line X linner
respounce to this .
Thank you
I never heard of that product, so I can't really help you much. However, any
"small rust holes" should be aggressively probed, as the rust may be a lot more
extensive than just what you see. There are some specific hull locations that
are very prone to rusting, and the rust may have spread quite a bit before
penetrating the layer of steel.
Any patch should consider water-tightness, and also structural integrity. And be
sure you coat the patch with a good rust inhibitor, either an epoxy paint or
something like POR-15. And don't forget to treat the rear, or inside, of the
patch as well.
