Light Pole Internal Thread Size
LNZCRFT
Does anyone know the thread size of the inside of the light pole.
The area where the lower connection is made.
Mine needs to be retapped, before I put the new parts in. It appears to be dented a little bit and I want to run a tap through it.
Or does anyone have this size tap?
Any help would be appreciated.
Canadian four amphs
I have NOS replacements for the bottom of the pole light with me here in Florida.( cost around $40) Hardware stores have a board with tread samples on them , I could take it in and see if I can find a match, it is a very fine thead about the size id a finger, the tap would be a specailize one that would have to be got from a speciailzd store($$$$)'
the other choice would be to take it to a machine shop and they could do it all for you.
GORD SOUTERS AMPHICARS
FL.#1 352 319 6774
(AMPHICAR CANADA)
Akamphi Pole light General Amphicar Discussion 2
T Light bulb for pole light for Dolores General Amphicar Discussion 13
C Nav light pole mounts General Amphicar Discussion 2
L Marine Pole Light Blowing Fuses General Amphicar Discussion 3
J Pole light door seals General Amphicar Discussion 2
C Rear pole light General Amphicar Discussion 0
A Light pole socket repairs General Amphicar Discussion 1
M Orignial Black Pole light Sockets General Amphicar Discussion 0
D Light Pole General Amphicar Discussion 2
M Pole light help needed General Amphicar Discussion 0
R Back up light switch General Amphicar Discussion 4
azpaul50 Tail/Marker Light Differences General Amphicar Discussion 0
Akamphi Backup light gaskets General Amphicar Discussion 1
B Bow Light Paint General Amphicar Discussion 11
B Marine light General Amphicar Discussion 6
C Wiper/Marine light dash switch placement ques. General Amphicar Discussion 1
C Bow light General Amphicar Discussion 6
B A NEW Amphi has seen the light of day!! General Amphicar Discussion 3
C New Member Intro "Cruiserdog" - Questions - Navigation Light Source General Amphicar Discussion 3
D nav light river cruise fifth swim General Amphicar Discussion 1
F Nav light General Amphicar Discussion 6
L "Foggy" Parking Light Lenses General Amphicar Discussion 2
B Darkness and Light General Amphicar Discussion 0
A Head light Ground General Amphicar Discussion 2
B Top light installation questions General Amphicar Discussion 1
M Marine Light General Amphicar Discussion 6
D light on Erics car General Amphicar Discussion 0
P Missing Marine Light General Amphicar Discussion 10
A Head light trim needed General Amphicar Discussion 2
D Light on dashboard bilge pump switch General Amphicar Discussion 1
