License Plate Lamp Question???
Tedredamphi
Which is the correct installation of the license plate lamp covers? Flat silver side toward front or back of car? Does anyone have a good "o-ring" idea for the gasket? Also is there an electrical ground for the rear deck lid or does it ground through the hinges and latch?
Ted
Hello Ted,
The flat sides goes towards the rear of the car and yes, those lights ground through the hinges. If Gordon's doesn't have those gaskets, I don't know of anyone who might have them separately but Allan Woodcock has some used Mercedes lights and they probably use the same gaskets. The last I hear of he was selling them for not many dollars.
Tedredamphi
Looks like a 2 inch by 3/32" O-ring can be made to fit. Will have to shorten it slightly and glue the ends back together with superglue. 1/16" O-ring is a little too small. Gordon Imports does not sell the gasket.
Ted
Yes, you can often get away with grounding through hinges. OTOH, it's not
the "right thing" to do. It doesn't take much effort to run a bypass ground
strap across a hinge point. Not only better for DC reliability, but also
helps to keep the engine cover at DC ground, helping suppress ignition
noise.
IAOC Membership Registrar
El Cajon, CA USA
WB6WSN
1961 Amphicar 770
1987 MB 420SEL
_____
Sent: Monday, August 09, 2010 8:19 PM
To: edprice@cox.net
Subject: RE: [General Amphicar Discussion-t-20854] Re: License Plate Lamp
Question???
Hello Ted,
Tedredamphi
#88 O-ring works good for replacing gasket on original license plate lamps. It is 2-1/8" O.D. x 3/32" thick. Had to cut about 1/2" off and superglue the ends together. It fits nice and snug into the groove of the original lens.
I also have a pretty good extra set of original license plate lamp sockets and lenses if anybody is interested. E-mail or P.M. me if interested.
Ted Matthews
sdreich California License Plate AMPHICR General Amphicar Discussion 0
S License Plate Bulbs? General Amphicar Discussion 3
S Replacement License Plate Bulb General Amphicar Discussion 1
A License Plate Lites on E Bay General Amphicar Discussion 0
B any license plate list? General Amphicar Discussion 3
Jon March some fun license plates General Amphicar Discussion 0
B Magnets for license plates General Amphicar Discussion 0
W Trailer license General Amphicar Discussion 3
Jacques B. Amphicar pressure plate and clutch disk General Amphicar Discussion 3
jfriese California Vanity Plate General Amphicar Discussion 2
azpaul50 Vanity Plate General Amphicar Discussion 4
T Data plate information General Amphicar Discussion 1
LSolheim Drum/Back-Plate Interference? General Amphicar Discussion 7
C Rear horizontal bumper panel repair & Skid plate questions General Amphicar Discussion 1
T AM/FM/SW band radio / Dummy plate General Amphicar Discussion 0
R engine plate General Amphicar Discussion 1
T I got the pressure plate blues General Amphicar Discussion 0
S Emergency Brake Connection Plate General Amphicar Discussion 0
E Radiator Marking Plate General Amphicar Discussion 0
S I need pressure plate springs, AGAIN General Amphicar Discussion 0
D amphi plate General Amphicar Discussion 1
A Licence plate ideas General Amphicar Discussion 11
M Broken pressure plate lever spring General Amphicar Discussion 0
W Amphicar Boat Sticker/Plate General Amphicar Discussion 0
T Spare parts manual Plate 49 General Amphicar Discussion 0
Akamphi Bilge pump switch lamp General Amphicar Discussion 3
jfriese Bilge Pump Switch Lamp General Amphicar Discussion 2
