S
Steven D. Reich
<table>
<span class="830082605-21112001"><font face="Arial" size="2">Hi-</font></span>
<font face="Arial" size="2">When you take an Amphi into water where exits are few, whether it be the ocean, San Diego Harbor, a large lake, or a river, you want a car that is leak-free and /or a high output second bilge pump. I have a car that I take into deep, salt water, so I feel most comfortable when it is leak-free. If you've ever seen an Alka-Selzer dissolve, then you know what it's like to take an Amphi into salt water. So, how do you isolate leaks? I have a few examples, but I would like to learn from the experience of others.</font>
<font face="Arial" size="2">Doors are the most likely source of a leak assuming that you've remembered to put in the bilge plug. I actually carry a checklist of things to carry and remember, such as put in the bilge plug and latch the doors. The problem is that I sometimes forget to look at it. I have had one major leak when the bottom door lock didn't catch. Easy fix, but when the upper latch strike plate is loose, it may not be obvious. Those screws do loosen.</font>
<font face="Arial" size="2">Major leak occurred when the seam in the rear wheel well split. It wasn't obvious because the water comes in under the floorboard. Plumbers putty fixed the problem although the rear quarter panels will have to be replaced soon.</font>
<font face="Arial" size="2">I get some leaks into the trunk. The rubber seal is new and the lid seems to fit. I do not think I get too much leakage through the headlights even though I do not have seals. I like to run at full speed so I often bury the hood under water. Some water gets in (because the trunk is wet on top of the trunk boards), but it's really not much.</font>
<font face="Arial" size="2">Just so you know, I do not count water coming over the windshield on fast entries or large swells as leaks.</font>
<font face="Arial" size="2">I have used the light trick to find leaks without success. This is where you put a light in various places inside the Amphi and look for light outside. I have tried flooding the car with water with no success. Most seams are high above the low point of the car, so you don't see a leak out. You have to be careful to keep the water level below the clutch plate or you bear the risk of getting oily water on the plate (that's bad).</font>
<font face="Arial" size="2">I did find a leak while looking into the engine compartment when the car was in the water. It looked like the vertical bar bumper screw hole was leaking, but it turned out to be a hole in the hull nearby.</font>
<font face="Arial" size="2">Axle boots are another logical source, but mine seem to be in good shape.</font>
<font face="Arial"><font size="2">Anybody else have a favorite leak spot?<span class="830082605-21112001"> Yes, Bilgemaster, I have checked the Archives, but my car is leaking now, not years ago.</span></font></font>
<span class="830082605-21112001"><font face="Arial" size="2">-Steve</font></span><span class="830082605-21112001">
<font face="Arial" size="2">'64 red (CA: AMPHICR)</font>
<font face="Arial" size="2">'64 red (CA: I SWIM 2)</font>
<font face="Arial" size="2">Del Mar, CA</font></span>
