Is transmission venting necessary
  • Thread starter rdboggie@juno.com
  • Start date
rdboggie@juno.com
The previous owner used rubber plugs in the transmission fill holes. I have
since replaced them with the original caps. I do notice trans fluid being pushed
out after a while. I'm guessing the inner seal is already blown. Can I do any
additional damage (beyond the seal) if I put the plugs back in? Does it need to
breathe? It would be nice to keep the fluid IN the transmission.
Randy
Al Heath
>> ...previous owner used rubber plugs in the transmission fill holes.
...replaced them with >> the original caps ... notice trans fluid being
pushed out after a while. ....
>> Randy
Are your double lip oil seals on the axles letting water into the tranny
forcing the oil out the top filler/vents?
Al
rdboggie@juno.com
Re: Re: Is transmission venting necessary
I installed new double-lipped seals a few months ago. It usually happens when
I'm going down the road. Similar to what's been posted here recently...fluid
moving from the water tranny to (and out of) the land tranny.
Randy
Bill Connelly
when I'm going down the road. Similar to what's been posted here
recently...fluid moving from the water tranny to (and out of) the land
tranny.
Randy
Randy,
Your tranny hasn't budged in 7 years, so a little stiffness of the seals and
whatnot is to be expected. Unless the levels really plunge towards empty at
either the land or water tranny side (the Club's 2002 Members' gift tranny
level dipstick will be a big help here, fitting right handily in the glove
compartment ), consider this season a breaking-in period.
Drain all your fluids at the end of the season, including both trannies the
"hard" way (see http://www.amphicar.com/restoration.htm#trannies ) to best
flush out the cobwebby cruds, and all will probably be well next year, with
your gear oils likely to be a lot less migratory.
I'm really glad you're finally afloat. It's nice to have another Amphi
that's a local call.
~Bilgey~
Randy Bograd
Thanks Bill. I'll keep an eye on the fluid levels and do the recommended
changes. Took it out again Monday evening to Seneca...and again, another
blast. A couple of observations:
People seem to routinely travel with cameras in their pockets. Everyone
who saw us seemed to have one.
The Amphi is a road hazard. Other drivers will watch an Amphi forever.
As a road car, the Amphi is only car I've driven that also has pitch and
yaw.
May try putting in at the 'Mouth of Monocacy' near Dickerson this
weekend. Just a few miles farther.
Later.
Randy
On Tue, 3 Jun 2003 20:23:41 -0400 "Bill Connelly" <billiam@erols.com>
writes:
> happens
> land
> tranny.
> Randy
> Randy,
> seals and
> empty at
> tranny
> glove
> trannies the
> to best
> year, with
> Amphi
> ~Bilgey~
> THE AMPHICAR-LOVERS LIST
> Archives:
> visit:
> at:
> amphicar770@yahoo.com
> This list is provided as a free service. Please support our
> sponsors at:
John Howland Transmission fluid levels General Amphicar Discussion 4
C Noise from transmission or clutch General Amphicar Discussion 5
Jon March Nice video that shows land transmission drainplug General Amphicar Discussion 7
jfriese Transmission Dipstick General Amphicar Discussion 4
T Transmission Fun General Amphicar Discussion 0
B Transmission oil leak General Amphicar Discussion 4
B Transmission oil leak General Amphicar Discussion 7
Steve Transmission leaking oil General Amphicar Discussion 7
Midwest Amphicar Transmission Tech Session at Gators Amphicar March 21st + lunch General Amphicar Discussion 5
jfriese Looking for Transmission Tool General Amphicar Discussion 2
MAE Transmission for Sale General Amphicar Discussion 0
E Transmission fluid level General Amphicar Discussion 2
Midwest Amphicar Transmission for sale General Amphicar Discussion 10
C Rust free body with extra NOS transmission on Ebay General Amphicar Discussion 3
sdreich Amphi Transmission Removal General Amphicar Discussion 5
Midwest Amphicar Transmission tunnel boot opinion General Amphicar Discussion 3
B Transmission mystery solved General Amphicar Discussion 3
E Transmission Oil & Differential Oil General Amphicar Discussion 1
G Transmission Symetry General Amphicar Discussion 0
B transmission leak General Amphicar Discussion 2
L Transmission gear oil leakage General Amphicar Discussion 19
K Modified transmission mount bolts General Amphicar Discussion 0
G Transmission Rebuild General Amphicar Discussion 1
L Transmission oil seals General Amphicar Discussion 2
D Lake of the Ozarks transmission for sale General Amphicar Discussion 0
S Transmission Linkage pops out.... General Amphicar Discussion 5
W Transmission rebuilt cost General Amphicar Discussion 1
W Transmission rebild General Amphicar Discussion 1
W Transmission bearings and gaskets General Amphicar Discussion 0
D reversing transmission General Amphicar Discussion 0
R new transmission for sale General Amphicar Discussion 0
S Rebuilt transmission installed General Amphicar Discussion 2
E Transmission Input Shaft Radial Play General Amphicar Discussion 1
A Transmission Plug General Amphicar Discussion 2
E Transmission Removal General Amphicar Discussion 5
S Transmission Levels General Amphicar Discussion 2
S Transmission Dip Stick General Amphicar Discussion 1
D Transmission Bummer - Update General Amphicar Discussion 0
