L
Larry & Nancy Solheim
She's cleaned-up, greased-up & back together, but
continues to exhibit the "intermittant stop" problem.
I think I've narrowed it down to the relay contacts
under the light aluminum shield over the electrical
connections.
Question: Just how should these sit in power off
condition & what is their movement in normal operation
when power is applied? I lightly filed the contacts
and now have continuous operation w/ switch on and a
hickup (slight stop) before the motor keeps on running
when the switch is turned off. I figure I moved
something, but at least have found an area of attack.
It appears
--31 is case ground
--53a is fixed contact
--31b is short flex arm (not touching anything at
present
--53 is long flex arm which is resting against the
fixed contact.
--LarryS
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
connections.
It appears
--31 is case ground
present
fixed contact.
--LarryS
Do you Yahoo!?
