alaskanamphi@gci.net
I'm going to dive into my starting system and am looking for some info. In the
past a previous owner disconected the wirening from the bilge blower, mounted a
ford type solinoid switch on the fire wall instead of the original with the push
botton and installed a push button next to the ignition switch. I'd like to get
the system back to original. Is there anything different in the way the original
solinoid is wired up as compared to a Ford type? I found the originl push botton
solinoid switch in the trunk and hope to test it and see if it is working. If I
need to replace the ignition switch can a lock smith easily match it to the
glove box and doors? The key I got with the car was a shortened down GM key that
does not work in the doors or glove box. I'm not sure if my ignition swich is
original or not. Is there an easy way to tell? It has a momentary starting
position but does not do anything. Currently to start the car I turn the key to
the on position and push the button th
at was installed next to the key. Yes some ya hoo drilled a hole in the dash I
will need to patch when I get the systen back to original. I'm hoping the bilge
blower can be hooked up and will work with the timer and push button at the
heater controll. Anyway thanks for any advise.
Craig in Alaska
Red 66 (FLATLK)
Craig in Alaska
Red 66 (FLATLK)
I may try that sometime soon.
