Hull Drain Pipe (Leaks)
No, not the big hole in the bilge at the right rear.
There's another drain hole; actually, a tube. If you have a mysterious hull
leak, maybe you should have a look at this tube. What I'm talking about is a
drain pipe that allows possible water in the very front compartment (under the
spare tire and in front of the steering linkages) to drain into the bilge near
the shifter base. This drain tube poses a leak condition to the main bilge and
the forward compartment.
The tube is steel, and was welded to the hull at both ends. Enough rust, or some
physical damage while working on the steering, and you can have one or two hull
leaks.
Ed,
The correct marriner's term for this tube is called a "limber hole".
I don't know why, but that is what I'm told by an old Captain I know.
In ships, they have a similar item that drains water past each
bulkhead or stringer to the pump.
I have not seen any that leak, I have seen a lot that are plugged.
Use a coat hangar or stiff wire, followed by a blast of air to clean
it out regularly. If it is plugged, that material can hold water
which is the fire that fuels rust. You should not have any water
standing in the trunk.
Rocky Mountain Amphicar
Midwest Amphicar Ahhh go to hull Restorations in progress 7
Midwest Amphicar proper or improper way to check hull General Amphicar Discussion 5
CapnJohn Free hull! General Amphicar Discussion 2
A hull protection coatings??---other than paint on the outside?? General Amphicar Discussion 5
C Underside hull paint and engine compartment paint General Amphicar Discussion 6
A Space between prop and hull General Amphicar Discussion 2
R gauge of the hull General Amphicar Discussion 0
V hull paint General Amphicar Discussion 4
dutchamphi Oil drain plug removal General Amphicar Discussion 2
J Oil Drain Kit (Second Request) General Amphicar Discussion 0
J Oil Drain Kits? General Amphicar Discussion 0
R drain plugs General Amphicar Discussion 0
R Magnetized Drain Plugs General Amphicar Discussion 0
R access to the land gearbox drain plug General Amphicar Discussion 0
T Oil Drain Plug Socket General Amphicar Discussion 4
K Battery current drain solved General Amphicar Discussion 1
T Manifold drain tube question General Amphicar Discussion 4
Jon March How to fix leak where J-pipe enters muffler? General Amphicar Discussion 0
T Chrome Bilge outlet Pipe General Amphicar Discussion 4
J Chrome tail pipe tip General Amphicar Discussion 0
R Cable cover and cheep tailpipe pipe seal General Amphicar Discussion 0
D Intake manifold copper pipe p/n 1-05-13 General Amphicar Discussion 0
