How to fix leak where J-pipe enters muffler?
Jon March
Black soot, a bit of exhaust snell..
..and noise
Even tho i cut “slits” in the entry-collar, the stainless U-clamp does not seal as well as it apparently needs to.
Gerry Obara added a flex-union and triangle-junction plate to where they meet to allow flexing and apparently doesnt leax exhaust.
Any other ideas in what i can do? if i dont want to bring it to have that done?
(That area definitely has flexing: i dont imagine tthere is hi-temp, removable wrap/ tape that stays flexible that would seal it...would probably always come unwraveled...)
(The black residue you see is from the burned adhesive from the silver aluminum hvac tape i tried--but some exhaust gases jetted out even from under that, so i removed it, leaving charred stickum residue)
B Transmission oil leak General Amphicar Discussion 4
B Transmission oil leak General Amphicar Discussion 7
B Tranny leak cured, onto the brakes General Amphicar Discussion 4
B transmission leak General Amphicar Discussion 2
J Fuel Reserve Valve - How to fix the leak. General Amphicar Discussion 0
W water leak General Amphicar Discussion 0
J Takin a leak... General Amphicar Discussion 5
Jon March Handbrake cable - where it enters from outside General Amphicar Discussion 1
E Where to start? General Amphicar Discussion 10
Jon March Where can i get a key copied? General Amphicar Discussion 4
mike_israel So, this is where all those Amphicars and parts went General Amphicar Discussion 1
D Where is Rock the Rock with The Wave? General Amphicar Discussion 0
C where to get a water pump General Amphicar Discussion 0
B Where does the time go? General Amphicar Discussion 4
R Where are Timing Marks General Amphicar Discussion 4
C Where are the pictures? General Amphicar Discussion 1
D Where to start General Amphicar Discussion 0
G where is Orillia General Amphicar Discussion 0
T Chrome Bilge outlet Pipe General Amphicar Discussion 4
J Chrome tail pipe tip General Amphicar Discussion 0
E Hull Drain Pipe (Leaks) General Amphicar Discussion 1
R Cable cover and cheep tailpipe pipe seal General Amphicar Discussion 0
D Intake manifold copper pipe p/n 1-05-13 General Amphicar Discussion 0
