Horn Repair
Tedredamphi
I have two original horns neither of which works. Is there an archived post with information about rebuilding the horn? Manual mentions setting the gap, but couldn't find the specs. That might be a moot point, since both of my points look like they've welded themselves together and then broke off the front arm.
Anyone have recommendation on a replacement horn or comments on the one that Gordon Imports sells?
Ted
I have a whole drawer full of old horn =NFG. I have even shipped some out to guys just for the shipping, cause if you fix one it only seems to work for a while then quite again..
Just put one of my drop in. replacements and away you go.
on yea, even they can go wrong sometimes but much better odds.
Hey Dave D, I sent you one with that last floor rubber????
GORD S>
There is a Bosch VW bug horn that is a direct bolt in...even sounds like an Amphi one and all screws align. They arent that easy to find though. There are other VW horns that will work if you add shims, washers etc. Look on Ebay and "The samba.com"
bkahler
I bought a horn off of eBay from a volkswagon dealer and it fit perfectly.
Haven't tried it yet since the horn is the only thing that is done on the
car :)
On Fri, Oct 1, 2010 at 12:08 PM, canitfloat
Tedredamphi
This Hella horn for VW bus, bug, ghia will probably fit (and sound) perfect. Being sold on ebay item # 150497216270.
Ted
Midwest Amphicar
For little money Gord Souter sells a horn with bracket attached. His does fit and sounds correct. His floor mat kit is also a bargain. I am a bit biased he always gives Me a professional discount!! And I don't have to melt My snowballs to get it. Later Dave the Wave
gzink
First post mentioned points that can be adjusted. My horn makes short sound/buzz but not really a honk so it works but not quite right. anyone know about adjusting it?
Greg Z (Michigan)
--- On Fri, 10/1/10, Midwest Amphicar <> wrote:
Subject: RE: [General Amphicar Discussion-t-20897] Re: Horn Repair
To: g_zink_us@yahoo.com
Date: Friday, October 1, 2010, 10:19 PM
I have repaired many original Amphicar horns and have a number of them in stock. Repairing them can be a bit tricky but they sound louder and better than any aftermarket versions I've heard.
You do the final adjustment in place, with the body parts and grill attached, by adjusting a screw on the right side of the horn. You access this screw through the the openings on the back of the horn housing. It's a trial and error system since you generally cannot hold a screwdriver in the slot when sounding the horn.
From my collection of arcane comments:
I used horns from a 80 Honda CB750F motorcycle.
All I had to do was drill 2 more holes to accommodate the horn body screws.
The horn then fit perfectly into the horn body.
Ken Roy
I just found an almost identical Amphicar horn & chrome (no body).
The chrome even looks almost identical.
Check out website
<http://www.parrautomotive.com> www.parrautomotive.com & look for part #
PRR0275 for $19.95
The horn (with chrome) fit perfectly into the Amphi horn body.
You'd have to drill out a couple of the rivets & use the original screws to
hold it in. (Source Unknown)
Membership Chairman
International Amphicar Owners Club
El Cajon, CA USA
WB6WSN
1961 Amphicar 770
1987 MB 420SEL
_____
Sent: Friday, October 01, 2010 9:09 AM
To: edprice@cox.net
RalphF Our horn button emblem holds a Guinness World record (sort of) General Amphicar Discussion 2
Propcar50 Horn Problem Revisit General Amphicar Discussion 2
Midwest Amphicar Canadian horn kit General Amphicar Discussion 0
Midwest Amphicar Horn shell wanted General Amphicar Discussion 2
T Amphica Horn Grille on ebay General Amphicar Discussion 0
jfriese Horn Grill General Amphicar Discussion 2
auburnamphi Help with horn General Amphicar Discussion 9
S Triva Question- Castle on Horn Button General Amphicar Discussion 5
R Original Horn Help? General Amphicar Discussion 2
K Amphicar Horn General Amphicar Discussion 4
D Horn button restoration - Sabula getting bigger- fabulous fins General Amphicar Discussion 0
K Amphi horn General Amphicar Discussion 3
J Horn Buttons General Amphicar Discussion 0
A VW Vs. Amphi horn buttons General Amphicar Discussion 1
A Horn Face Chrome Screw Needed General Amphicar Discussion 0
A replacement horn General Amphicar Discussion 3
P Horn General Amphicar Discussion 0
peterboz trunk cover repair weld or glue the skin General Amphicar Discussion 1
Midwest Amphicar Flat quarter repair General Amphicar Discussion 1
T Oil Cooler connector repair General Amphicar Discussion 3
cigarman Axle Tunnel repair (welded in wrong) General Amphicar Discussion 4
C Rear horizontal bumper panel repair & Skid plate questions General Amphicar Discussion 1
A Axle tunnel repair General Amphicar Discussion 0
D electrical repair General Amphicar Discussion 1
R Top repair and storage within a sealed car cover General Amphicar Discussion 0
C REPAIR PANELS General Amphicar Discussion 2
D Tranny Repair General Amphicar Discussion 1
A Radiator Repair General Amphicar Discussion 6
E Body Repair General Amphicar Discussion 2
M Rear Quarter Repair ??? General Amphicar Discussion 0
M Steering Box Brace - A Critical repair!! General Amphicar Discussion 6
C Body panel repair General Amphicar Discussion 8
A Trim polishing / Bumper repair General Amphicar Discussion 0
A Trim polishing/straightening - Bumper repair General Amphicar Discussion 0
T top repair General Amphicar Discussion 7
C Great article on Steering wheel repair General Amphicar Discussion 0
B How To Videos for Amphicar Repair & Restoration General Amphicar Discussion 0
