Help with weatherstrip
auburnamphi
I am working on my top,putting new weatherstrip along the top where the windows roll up into.Which way does it go? Can someone tell me or show it in a picture.
CapnJohn
If you can, warm up the rubber in the sun or in a tub or hot water before starting. The materials used for the Hugh's weatherstrip there are incorrect. It is way to hard (should be somewhat soft as originally intended). I use a large flat screwdriver (I rounded off so there are no sharp edges) to force the seal into the aluminum moldings. I hope Hugh has the next batch done with the proper softer materials.
The center "flap" goes so it faces out and will mate with the window's top/inside edge. Keep in mind the window will close against that edge when you close the door against it. I hope all makes sense!
DrNoose
Agreed on the material used being way too hard. I ended up having to use a bench grinder to thin it off on the back and then go after it with a screwdriver. The job took several days and my hands ached after it was complete.
amphi_sc
I used plenty of warm soapy water. Didn't have a problem. But that was 10 years ago and maybe different material.
auburnamphi
Thanks for all the ideas with getting it into metal frame.But what I need to know is;does the longer part go to the inside or outside? The frame has a slot that the weatherstrip slides into and the other side needs to be push into.I may have the frames reverse.I have tried both ways,Niether seems to look right.
Also,I am looking for a pair of sunvisors,and the horn body in any condition.Any help there?
Thanks Steve
Amphicar Forum Admin
Staff member
Best bet for sun visors is Allan at amphicarparts.com
Gord Souter has repro horn shells in fiberglass.
CapnJohn
Thanks Steve
The longer part will be towards the inside.
DrNoose
I bought a pair of VW visors and fitted them to my original visor rods.
They work and look great.
Dan
> Thanks Steve
DougFromBaltimore Convertible top - Help with weather-strip over side windows General Amphicar Discussion 4
S Newbie ... help me find a car please? General Amphicar Discussion 1
Jon March gauges - any help appreciated General Amphicar Discussion 1
Jon March searched for an hour- cant find the answer- help? General Amphicar Discussion 1
Jon March Alternator wiring help please General Amphicar Discussion 10
Jon March we could all use help with this Amphi issue: General Amphicar Discussion 0
Midwest Amphicar Carb or ? help General Amphicar Discussion 5
Midwest Amphicar Printed knobs help General Amphicar Discussion 0
Midwest Amphicar Help identify this magazine General Amphicar Discussion 0
F "Amphicab" Urgent Help Needed General Amphicar Discussion 2
Midwest Amphicar Temp gauge help General Amphicar Discussion 6
J help with mounting new upholstery General Amphicar Discussion 3
Midwest Amphicar Tavares Lake Harris ramp help needed General Amphicar Discussion 3
Ed Price RE: Help with posting to the e-mail list General Amphicar Discussion 0
Midwest Amphicar I need help in Mesa/Phoenix General Amphicar Discussion 1
auburnamphi Help with horn General Amphicar Discussion 9
Midwest Amphicar Celina extra bed/ floor ....Help General Amphicar Discussion 2
H help? !???! General Amphicar Discussion 1
auburnamphi need some help General Amphicar Discussion 5
Tom Laferriere Help with Wiper Blades and/or Arms General Amphicar Discussion 27
D Shipping help - Monticello Mn to Illinois General Amphicar Discussion 0
R Original Horn Help? General Amphicar Discussion 2
C Fwd: Anyone near Lancashire, UK who could help with transport to the port for... General Amphicar Discussion 1
D 1300 Cam Help General Amphicar Discussion 3
D Parts help needed rear reflectors General Amphicar Discussion 3
D Really a 63? German help Tires needed reproduction tags General Amphicar Discussion 4
L 1300 help General Amphicar Discussion 15
B Maybe fellow water lovers can help General Amphicar Discussion 0
R Need help - How to flash my generator General Amphicar Discussion 0
B Wiper Help General Amphicar Discussion 3
D electric fan help General Amphicar Discussion 1
R Help identifying clunk General Amphicar Discussion 1
D Parts help!! General Amphicar Discussion 0
S triumph window fuzzies.........HELP General Amphicar Discussion 2
T help with picking up Amphi General Amphicar Discussion 0
A can anybody help? how to convert konvensional car to amphibian? General Amphicar Discussion 5
R calculation help needed General Amphicar Discussion 1
D Great Son -Museum/restoration help wanted General Amphicar Discussion 0
C Can anyone help me? General Amphicar Discussion 4
D help with axle idea ---- Great book General Amphicar Discussion 2
B help Amphicar General Amphicar Discussion 1
C help not Amphicar General Amphicar Discussion 2
L Shock Problems - Spring Help Needed General Amphicar Discussion 1
C Amphicar questionairre! Please help! General Amphicar Discussion 0
D Tranny Help Needed General Amphicar Discussion 1
R HELP! Please General Amphicar Discussion 0
