help with mounting new upholstery
jwillia
I am wondering what the preferred mthod is for mounting new upholstery panels. Any sugeestions greattly appreciated.
Thanks Jeff
Red 62
Rear panels, use 3 clips across front 2 down sides.
seat will keep rear in. cut out hole for window cranks after install to get exact spot.
Fronts, you must cut out for water lock 1st, clips must be all the way in and close to door panel edge. no high build up of materials in corner on back side,.
then they just snap on. Done! put felt on, then handles. etc.
note top clip at front door rear may hit bolt for window track, Use shorter bolt.(or cut it down)
I stock the clips($1.00 each)
I have a good deal on a yellow kit right NOW but John B has 1st dibs on it.
GORD.
Thanks Gord
To: jeffreyd_7@hotmail.com
Subject: RE: [General Amphicar Discussion-t-20724] Re: help with mounting new upholstery
Date: Sat, 10 Apr 2010 21:36:42 -0400
then they just snap on. Done put felt on the handles. etc.
GORD.
GORD.
I just installed my new interior door and quarter panels I got from Gord and they fit perfectly. Thanks for the nice job Gord!
