Ted, both MetalBeast (early '64) and Amphi ('66) have/had the heater under
the fuel tank and are/were setup as John pointed out. Defrost/heat flapper
on left, fan in center & water valve (which I always leave on to add that
little bit of coolant into circulation) on the right.
Sounds like you are doing a top-notch job!
--Larry
Sent: Wednesday, October 22, 2008 7:26 AM
To: lrsnpark@gmail.com
Subject: RE: [General Amphicar Discussion-t-20211] Re: Heater and Defrost
Cables
John,
You have the late model Amphicars with I believe the heater over the wheel
well area. Can anyone with an early early car like mine with the heater
underneath the fuel tank confirm the switch/cable position??
Amphicar repair manual says that left knob controls the heater and right
knob controls the cock(valve for hot water), however drawing at front of
section 9 in the repair manual shows knobs/cables hooked up just opposite!!!
Ted
