Headlight Switch
Steve,
Although people complain a lot about Lucas electricals, I've found that all the switches and lamp sockets I've had trouble with can be taken apart and cleaned. I don't specifically remember about the light switch but take a look and see if it doesn't have small metal tabs that can be bent out and the plastic part removed to access the insides for service. I don't think I had to replace any of the switches but I know I opened several up for cleaning. I also had good luck with servicing the lamp holders used in the gauges. I don't think they open up but contact cleaner and some cleaning fixed them up.
mschlem
I have used THIS inexpensive switch since 2008. I re-tapped the stock knob to fit the shaft threads. --Larry
Here's an update on Larry's switch suggestion.... as of early 2014, this is still a good P/N. Switch is an excellent choice for a replacement. And just as a point of documentation, the original chrome rosette fits this switch, and tapping the original knob as Larry suggested (10-32 threads) gives an original look.
Thanks, Larry!
Marc.
SNOWBIRD Headlight buckets General Amphicar Discussion 0
B Headlight rubber sealing ring General Amphicar Discussion 4
auburnamphi Headlight Rings General Amphicar Discussion 2
T New G.Imports Chrome Headlight Trim Ring Problem??? General Amphicar Discussion 1
K Headlight maintenance tips General Amphicar Discussion 0
A HEADLIGHT BUCKET General Amphicar Discussion 0
J Headlight Bucket WANTED General Amphicar Discussion 0
A HEADLIGHT PROBLEM General Amphicar Discussion 0
R Back up light switch General Amphicar Discussion 4
M water drive switch General Amphicar Discussion 4
Akamphi Bilge pump switch lamp General Amphicar Discussion 3
Akamphi Questing about ignition switch and bilge blower wiring General Amphicar Discussion 0
jfriese Bilge Pump Switch Lamp General Amphicar Discussion 2
B Ignition switch bezel needed General Amphicar Discussion 0
B Ignition switch bezel needed General Amphicar Discussion 1
C Wiper/Marine light dash switch placement ques. General Amphicar Discussion 1
T Dashboard Switch Question? General Amphicar Discussion 3
A Ignition switch General Amphicar Discussion 6
W kill switch for blower General Amphicar Discussion 1
A Wiper Switch General Amphicar Discussion 6
E Stoplight Switch General Amphicar Discussion 1
A Ignition switch and door locks General Amphicar Discussion 9
R Extra dash switch? General Amphicar Discussion 2
J Ignition switch needed General Amphicar Discussion 1
D Light on dashboard bilge pump switch General Amphicar Discussion 1
