Head light Ground
alaskanamphi
Can anyone tell me the location of the ground wire for the passenger side
head light? Is it in the bucket of in the wiring system some where.
Thanks, Craig
Flat lake Alaska
passenger side
> Thanks, Craig
It should attach via nut/bolt to the lip running just below the edge
of your fender about 3" from the front corner. If your other
headlight has the ground, you should be able to mirror the location.
It will also be a brown wire.
The ground wire on mine was attached along the lower lip of the inside
fender by a self tap screw. If fact, there are 4 of these ground
wires in all four corners of the car.
side
> Thanks, Craig
> Flat lake Alaska
