Handbrake cable - where it enters from outside
Jon March
see pics - it has opened up at the bottom (helped by the upward curvature)
can the outer jacket be carefully trimmed back & removed 1/4" inch or so? (Dremel wheel/right angle "pick-"-tool)- and then the new, clean end re-siliconed to the thru-body tube?
(the one on the pass side is even longer/arching up too much - so i need to clean up/shorten the black jacket a but more on that side even more..
mschlem
Jon,
There is actually an end piece on the black jacket that goes into the tube on the body. In other words, if you do what you're proposing, you could take that piece out of the body tube...and the jacket and cable out where you have a bit more room to work. While apart, be sure to check out the accordion rubber jacket on the inside of the car that seals at the opposite end of the tube shown in your picture.
You've done a lot of work on your car - you might want to consider replacing those cables since it seems that the jackets on yours are brittle and cracked.
The new ones have grease fittings to keep a little lube in there....plus you'll get new accordion boots on the inside of the car.
Marc.
Jon March pros/cons of early vs late handbrake ? General Amphicar Discussion 1
Mark Richardson Accelerator cable installation question General Amphicar Discussion 17
S Speedometer Cable - Update General Amphicar Discussion 0
S Speedometer Cable Replacement General Amphicar Discussion 4
A NEW CHOKE CABLE General Amphicar Discussion 1
D fight ing the clutch cable General Amphicar Discussion 3
A Accelerator cable length General Amphicar Discussion 0
D accelerator cable General Amphicar Discussion 1
R choke cable General Amphicar Discussion 10
B SV: Re: clutch cable General Amphicar Discussion 0
T Brake Cable Routing ??? General Amphicar Discussion 4
S I need a choke cable General Amphicar Discussion 0
J Battery Cable Quick Connectors General Amphicar Discussion 0
R Stainless Throttle Cable General Amphicar Discussion 1
S clutch cable General Amphicar Discussion 13
R Cable cover and cheep tailpipe pipe seal General Amphicar Discussion 0
M How to install a new speedometer cable...... General Amphicar Discussion 0
T Brake and park cable question General Amphicar Discussion 2
A Speedometer Cable Lube General Amphicar Discussion 0
S shift linkage/clutch cable General Amphicar Discussion 1
Jon March How to fix leak where J-pipe enters muffler? General Amphicar Discussion 0
E Where to start? General Amphicar Discussion 10
Jon March Where can i get a key copied? General Amphicar Discussion 4
mike_israel So, this is where all those Amphicars and parts went General Amphicar Discussion 1
D Where is Rock the Rock with The Wave? General Amphicar Discussion 0
C where to get a water pump General Amphicar Discussion 0
B Where does the time go? General Amphicar Discussion 4
R Where are Timing Marks General Amphicar Discussion 4
C Where are the pictures? General Amphicar Discussion 1
D Where to start General Amphicar Discussion 0
G where is Orillia General Amphicar Discussion 0
