chris_skeeles
My obsessive compulsive disorder, which has once again manifested
itself into my amphicar, drove me to fix the hand throttle cable
which has not worked for some time.
I remove seats, mats, floors, kick panels, everything to get to the
darned accelerator linkage. The throttle handle and cable all seem to
be in working order, but the opposite end of the cable is not hooked
to anything.
I refer to my maintenance manual, but the reference to the cable
system is lame if that. It says the cable hooks to the "pedal" but
then refers to "clamping nipple accessible from from trunk". Which is
it, and where is it?
I dont have a clamp on the end of the cable wire (obviously allowing
wire to become inoperable) but I cannot for the life of me figure out
where to put thise wire neverless a replacement nipple clamp.
There is one spot at the base of the accelerator lever (the lever
where the actual gas pedal rod connects). The cable does not go that
far down however, and the hole seems a bit large for such a small
cable/clamp.
A picture would be great, but probably somewhat ackward to obtain,
so a detailed explaination will help me out a whole bunch!
Where is the missing link?
Chris - Canton, Ohio
'63 Red - "Chaos"
to anything.
cable/clamp.
'63 Red - "Chaos"
