Grease Fittings needed
Randy Bograd
I need two king pin grease fittings for my '67. Turns out the front wheel
assemblies, when off the car, flop around enough to break these little
guys off. Gordons has none in stock. Please contact me offline to work
out the details.
Also, I have an alignment problem with the transmission and axle tunnel.
The transmission is about 1/2 inch higher than it should be (or maybe the
tunnel is 1/2 inch lower than it should be. The result is the inner
u-joints scrape against the upper portion of the tunnel. My current
option is to put some shims under the tunnels to raise them up a bit.
Anyone else experience this?
thanks,
Randy
Blue '67 in Gaithersburg, MD
