Got my boat numbers
Midwest Amphicar
Illinois really picked up the pace. 6 months + was the norm for numbers. Even with rejecting my Amphi the first time it only took 60 days. So once it stops snowing ........The black wonder can begin. This one will make Kamikaze's look mint. Later Dave the Wave
Midwest Amphicar
The black Shark and the 300 horse (estimated) 1300. Double valve springs and enlarged head studs. Hopefully it will have enough vroom to run AC compressor. Later Dave the Wave
azpaul50
All render tribute to Dave! Impressive!
To: azpaul50@hotmail.com
Subject: RE: [General Amphicar Discussion-t-20727] Re: Got my boat numbers
Date: Thu, 8 Apr 2010 17:50:52 -0400
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail.
http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5
Midwest Amphicar
:005: "estimated" 300 hp. But still a correct response!!! I did the Laughlin River Run some years ago. Wow, stories yup got 'em!! Later Dave . :D
azpaul50
We'll be at the Riverside RV park starting Thursday. A bunch of bros will be coming up on Friday morning followed by the Laughlin to Oatman to Kingman to Laughlin circuit. Ya' gotta watch for those wandering donkeys among "other" things up there! lololol...
Date: Thu, 8 Apr 2010 21:04:28 -0400
The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail.
http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4
Canadian four amphs
I have a 1300 in a customers car,( he reads these emails)
The SU carb next to the fire wall has no intake draft when you hold your hand over it.
when you hold your hand over the one next to rad , lots of sucktion, stalls out motor.
I have taken intake off, all 4 intakes have the same suck, comp. in all cyl is 150. there is no blockage in intakes,, we are checking out the carb, but still does not explaine no suction on that side .
Anyone else ever run into this?
GORD,
I,m not a SU expert..never touched them so there at a experts now.
Gord,
It's problems like these that make me use the Pierce/Weber carb. system. I use the carb. with manual choke so that the knob on the dash has something to do. Easy adjustment and it's even quite easy to use the original Amphicar air cleaner. The whole thing looks almost stock and works fine.
Jim Lichter
Gord,
Check for broken or worn lobes on cam shaft. If not borken, check valve clearance on cyl 3 & 4. If clearance is good, rebuild carb.
Jim
-----Original Message-----
To: jimlichter@aol.com
Sent: Fri, Apr 9, 2010 6:52 pm
GORD,
DavidC
Gord,
That's a known issue here with SU carbs, the damper piston will be stuck, it
may have no or the wrong oil in it. Undo the little black screw on top to
check. Sometimes it'll free up and be fine, sometimes it'll work for a while
but continue to cause grief until the point you give up, unbolt, and throw
it over the hedge !
Triumph changed to Stromberg carbs on the later 1300s probably because of
problems with SUs.
As John says, the Weber / Pierce solution works much better on 1300
Amphicars as the air intake is in the right place away from the muffler.
David C
Midwest Amphicar
I had dual SU's on another engine. When running good it ran great but.....Add steam/moisture and they would get gummy and sure enough the piston would stick. My 1300 has the Weber. John did you re-jet? *** ** off topic work on date for Ozarks. Later Dave
Dave,
That Pierce/Weber setup was originally done for the 1500 but they say it works on the 1300 too. I used mine with stock jets for several years but felt that, particularly on one car, when the second barrel opened the engine seemed a bit starved for fuel. Also sometimes the engines hesitated a bit on acceleration. I talked to pierce about this and they suggested enlarging the pump jet and opening up the high speed jets a bit. Since the 1300 engine was smaller than the 1500 it seemed counter-intuitive to me but they said the 1500 had higher vacuum and thus larger jets might work better on a 1300. Since then I went one step larger on the pump jet and on the main jets. This involves replacing the single pump jet with the next larger size and moving the larger high speed jet from the primary bowl to the secondary bowl. Then install the next larger high speed jet in the primary bowl. I don't remember the exact jet sizes right now but I can look them up , with their part numbers, if you want them.
Amphicar Forum Admin
Staff member
I have a NOS weber sitting on the shelf that I have been wanting to try out on my 1500 (I think it is from a Ford Pinto).
Where can I find the adapter plate for between carb and intake manifold?
Thanks.
Mike,
I use 1300 engines in my cars and the Pierce manifold made for the Triumph 1500/Weber DGV5A.
Staff member
I must be having a senior moment. I do not have a 1500, I have the stock 1147. I think, at one point, someone on the list custom fabricated some adapters for the weber carbs between the carb and the stock manifold ???
K Boat numbers General Amphicar Discussion 0
G 56th Annual Antique Boat Show Clayton, NY General Amphicar Discussion 0
Jon March Gord featured on TV at Gravenhurst Boat Show - Ontario General Amphicar Discussion 0
mike_israel Duck Boat Tragedy - Be careful out there General Amphicar Discussion 0
Midwest Amphicar Sunny Land boat show land locked ,Ha! General Amphicar Discussion 0
Midwest Amphicar Saturday visit to Sunnyland boat show General Amphicar Discussion 1
C Boat parade - 8/2/14! St. Paul, MN General Amphicar Discussion 0
T Making Good Use of a Boat Trailer General Amphicar Discussion 3
Midwest Amphicar 200+miles 72+mph 13 boat ramps General Amphicar Discussion 5
mike_israel [Aug 19, 2011] Beloit, WI - Midwest All-Classics Boat Show (Beloit, WI) General Amphicar Discussion 0
Midwest Amphicar Lets play August 20th Beloit Wisconsin -Finned boat show- cool! General Amphicar Discussion 4
mike_israel 2 missing after duck boat crashes into barge General Amphicar Discussion 1
Jacques B. New all usage 4x4/boat/amphibian General Amphicar Discussion 0
Midwest Amphicar Cool Guy Trailer Boat General Amphicar Discussion 6
C Amphicar Boat registration in Mass? General Amphicar Discussion 10
amphigill Boat Show in Wi. General Amphicar Discussion 0
A Boat Show in Wisconsin General Amphicar Discussion 0
A Door County Maritime Museum Boat Show General Amphicar Discussion 0
auburnamphi Boat Registration Problems for Amphicar in Georgia General Amphicar Discussion 12
R Lake Dora Boat Show General Amphicar Discussion 1
R Boat U.S. Amphibian Article General Amphicar Discussion 0
T Kool Boat General Amphicar Discussion 1
A Jet Boat verus Amphi General Amphicar Discussion 0
S WI Rules about boat registration General Amphicar Discussion 0
G boat reg General Amphicar Discussion 0
A Rules about boat registration General Amphicar Discussion 12
A Missing the boat... General Amphicar Discussion 1
W seattle boat show General Amphicar Discussion 0
D Amphi-Boat? General Amphicar Discussion 2
D Lake Geneva antique boat cruise General Amphicar Discussion 0
D Lake Geneva Antique Boat Club Invite General Amphicar Discussion 0
A Boat Registration General Amphicar Discussion 2
B Building a Boat Ramp General Amphicar Discussion 2
R Invitation to show Amphis at Seattle boat show General Amphicar Discussion 1
E 12VDC Boat Handbook General Amphicar Discussion 1
J Detroit Boat Show General Amphicar Discussion 3
W Fwd: boat show General Amphicar Discussion 0
W boat show General Amphicar Discussion 0
K Minneapolis boat show. General Amphicar Discussion 0
B Invitation to: Antique boat show (Minneapolis Area) General Amphicar Discussion 0
M A Boat to Haul Your Amphi Around On General Amphicar Discussion 1
K Boat Registeration General Amphicar Discussion 1
R Maryland Boat Registration General Amphicar Discussion 9
R Boat Car General Amphicar Discussion 0
A Loch Norman Car and Boat Show General Amphicar Discussion 0
W Rcaine Boat Show General Amphicar Discussion 0
W Racine Boat Show General Amphicar Discussion 2
M Registration as boat General Amphicar Discussion 9
B Insure Your BOAT Jeff! General Amphicar Discussion 0
