Randy Tusone
Hey all,
I would like to let you know about a car that is
currently in our shop. The car had been restored,
years ago, using lots of Gluv-it. Well, that turned
out to be a very bad thing for that amphi because the
gluv-it does not flex (like the metal of the car does)
and tends to come up and let small quantities of water
get underneath. Wherever the gluv-it was used on this
car, very bad rust was found.
For example: Gluv-it was used around the frame
sub-rails, the hull there needed to be replaced, as
well as, large portions of the sub-frame where the
gluv-it had been used.
Silicone is a bit more flexible, however, if it does
not truly make a chemical bond with the metal, it will
also lift and allow water underneath. As can the
POR-15. If you want to use something on a rusty area
that is in decent enough shape to keep and you want to
treat it, there is a Marhyde product that works really
well.
Be cautious.
Randy
Yahoo! Greetings - Send FREE e-cards for every occasion!
http://greetings.yahoo.com
well.
Be cautious.
Randy
