I have a write-up on converting an Amphi to use the Delco 7127 alternator.
(I bought a fancy all-chrome 7127 on eBay. <g>) Send me an email
(edprice@cox.net) and I'll email the MS Word document back to you.
The 7127 has a built-in electronic voltage regulator, so you can wire in the
7127 by bypassing or eliminating the old Amphi mechanical voltage regulator.
The 70 amp capacity of the 7127 is simply its maximum capability; it
automatically adjust to supply whatever your Amphi electrical system needs
at any given moment. It only takes a few amps to run the ignition and
gauges. Turning on the headlights draws about 10 amps, a super Rule bilge
pump is about 8 amps, and the Amphi blower is a bit less than that. Thus,
even with two bilge pumps running, blower on, and headlights on, you would
not be taxing the 7127 at all. The 7127 is a very generic and common GM
alternator, and will probably last longer than anything else on your Amphi.
El Cajon, CA USA
WB6WSN
61 Rust Guppy
1987 MB 420SEL
_____
Sent: Thursday, June 04, 2009 6:20 AM
To: edprice@cox.net
Subject: RE: [General Amphicar Discussion-t-20443] Re: Generator to
Alternator: Which One?
Any chance someone could be more specific on the model number of a GM
alternator that they have used. I've decided to go this route. It appears
from the pictures the one used is a 7127 model, which is 70 amps. Has anyone
found one that is lower amps? Is it necessary to use one with such high
amperage? Then again is there any harm in having to much? There was one I
found yesterday at the parts store that is for a 70's jeep that is 37 amps?
