Gear Shift Return Spring
S
Steven D. Reich
<table>
<span class="718412320-10022007"><font face="Arial" size="2">Hi-</font></span>
<span class="718412320-10022007"><font face="Arial" size="2"></font></span>
<span class="718412320-10022007"><font face="Arial" size="2">Please tell me where part 11-43-38 (Return Spring: Rebounding spring for pin 11-43-06 and aluminum bracket 11-43-02) goes. It is attached to a hole at the top of spring (11-43-07)assembly (11-43-02), but I can't figure out where the other end goes.</font></span>
<span class="718412320-10022007"><font face="Arial" size="2">Thanks.</font></span>
<span class="718412320-10022007"><font face="Arial" size="2">-Steve</font></span>
<span class="718412320-10022007"><font face="Arial" size="2">'64 red (I SWIM 2) with a new parking brake cable</font></span>
<span class="718412320-10022007"><font face="Arial" size="2">'64 red (AMPHICR)</font></span>
S
Steven D. Reich
<table>
WB6WSN
<table style="BACKGROUND-COLOR: #ffffff">
<div dir="ltr" align="left"><font face="Century Schoolbook" color="#0000ff" size="4"><span class="578492103-11022007">Steve:</span></font>
<div dir="ltr" align="left"><font face="Century Schoolbook" color="#0000ff" size="4"><span class="578492103-11022007"></span></font>
<div dir="ltr" align="left"><font face="Century Schoolbook" color="#0000ff" size="4"><span class="578492103-11022007">Just to give you a quick, but not quite definitive reply, that pin serves to provide a detent at the shifter positions equivalent to transmission gear selections. In other words, even if you didn't connect the shifter link at the transmission, the shift lever would "feel" like a gear has been selected.</span></font>
<div dir="ltr" align="left"><font face="Century Schoolbook" color="#0000ff" size="4"><span class="578492103-11022007">Now here I'm guessing a bit, but it looks like parts 6 & 7 (the spring and follower pin) slip radially into part 2a, and then the whole thing slips axially into part 2. Sorry for the guess, but those parts are buried way too deep to get at them now. Maybe this is enough to help you now; I'm sure someone will give you a better answer later.</span></font>
<div align="left"><font color="#0000ff" size="4"></font></span></font>
<font face="Century Schoolbook" color="#ff0000" size="4"></font>
<div class="OutlookMessageHeader" lang="en-us" dir="ltr" align="left">
<hr tabIndex="-1">
<font face="Tahoma" size="2">From: amphicar-lovers@yahoogroups.com [mailto:amphicar-lovers@yahoogroups.com] On Behalf Of Steven D. Reich
Sent: Saturday, February 10, 2007 12:33 PM
Subject: [amphicar-lovers] Gear Shift Return Spring
</font>
<div id="ygrp-text">
</blockquote>
WB6WSN
<hr tabIndex="-1">
</font>
</blockquote>
S
steve.reich@sbcglobal.net
Hi-
Turns out that spring is there to prevent the gear shift lever from
vibrating. One end is attached to the top of the compression spring
assembly and the other goes straight down and attaches under the
shift rod joint. The parts manual doesn't show the other side of the
shift rod joint where the spring attaches.
Thanks to Hugh Gordon for taking an emergency call at home and to Ed
Price for the engineer's point of view.
-Steve
'64 red (I SWIM 2) now ready for land and water
'64 red (AMPHICR)
--- In amphicar-lovers@yahoogroups.com, "WB6WSN" <wb6wsn@...> wrote:
> Steve:
serves to
transmission gear
link at
> selected.
spring and
slips
buried way too
sure
> Ed Price
> El Cajon, CA USA
> 67 Rust Guppy
> _____
Reich
> Hi-
spring for pin
hole at
> the top of spring (11-43-07) assembly (11-43-02), but I can't
figure out
> Thanks.
> -Steve
> '64 red (AMPHICR)
S
Hi-
-Steve
'64 red (AMPHICR)
> Steve:
serves to
transmission gear
link at
> selected.
spring and
slips
buried way too
sure
> Ed Price
> El Cajon, CA USA
> 67 Rust Guppy
> _____
Reich
> Hi-
spring for pin
hole at
figure out
> Thanks.
> -Steve
> '64 red (AMPHICR)
Jon March Taller gear possibility? General Amphicar Discussion 8
mschlem Non-synthetic gear lube General Amphicar Discussion 4
Jon March Water trans drive gear retainer clips: General Amphicar Discussion 7
okey0 What gear lube? General Amphicar Discussion 3
dutchamphi Window crank regulator gear General Amphicar Discussion 8
dutchamphi Gear Oil General Amphicar Discussion 2
C Third Gear General Amphicar Discussion 4
R 3rd Gear Clunk General Amphicar Discussion 5
L Transmission gear oil leakage General Amphicar Discussion 19
A Top Gear video General Amphicar Discussion 0
M Tranny Gear Lube Removal General Amphicar Discussion 5
E Speedometer Gear Ratio General Amphicar Discussion 0
B 1st & 3rd gear failure General Amphicar Discussion 0
C Left in Gear General Amphicar Discussion 1
E Hypoid Gear Oil General Amphicar Discussion 2
A Gear Noise General Amphicar Discussion 2
C Gear Mesh Noise Reduction General Amphicar Discussion 7
J Pumping out the gear lube General Amphicar Discussion 1
M Tranny gear oil General Amphicar Discussion 4
M Amsoil Gear Lube General Amphicar Discussion 0
okey0 Hard shift into 4th General Amphicar Discussion 8
C Angle water shift is mounted? General Amphicar Discussion 2
R shift boots General Amphicar Discussion 0
T shift boot General Amphicar Discussion 0
A Design Change for Transmission Shift Linkage? General Amphicar Discussion 0
S shift linkage/clutch cable General Amphicar Discussion 1
D Shift this General Amphicar Discussion 0
Bilgemaster Return of the Bilgemaster... General Amphicar Discussion 13
A Safe Return from Celina General Amphicar Discussion 0
