Gasoline, exhaust or bilge aroma?
  • Thread starter martyandcaryl@charter.net
  • Start date
It got way up to 42 degrees today and we both said "We should go
swimming", so I greased all the nips, checked vital fluids and with 3
little girls life preserved in the back seat we were off to Anchor
Inn.
The river was as smooth as glass today and our engine is running so
good, I guess the walleye weren't biting though, a few of the fishing
boats close to where we were splashing in and going out, splashing in
and going out moved on.
Do all Amphicars have an excess of gasoline, exhaust or bilge aroma?
Ours seems to have quite a bit more than we would like. We are
forced to drive with the windows down while the top is up. There are
no exhaust leaks from the engine assembly all the way to the end of
the muffler, no pat, pat, pat, pat on my hand around the gasket
joints. Our car seems to really suck the gas; it is clearly running
too rich.
Any suggestions on the subject that may help reduce or explain what
we are riding around in would be greatly appreciated.
Marty & Caryl
`64 Turq
BUOYANT in WI
Marty, see note about oil filler cap yesterday but the most likely cause is
air leaks around the back seat / convertible top area, the engine fan pushes
air forward under pressure and if the back seat isn't a good fit or if the
flexible seals that fit at each end of the bulkhead where it meets the rear
panels aren't airtight then air and fumes can be blown past.
David
That makes a lot of sense now that you explain it that way, we were
thinking maybe exhaust was coming in from behind the back seat. What
should we look for in flexible seals?
Marty & Caryl
cause is
fan pushes
if the
the rear
> David Chapman
D Gasoline Surf Board General Amphicar Discussion 0
Ed Price Exhaust Question General Amphicar Discussion 10
D Exhaust order General Amphicar Discussion 5
L Exhaust General Amphicar Discussion 7
D Stainless steel exhaust General Amphicar Discussion 3
G Exhaust Flange General Amphicar Discussion 0
A Exhaust manifolds General Amphicar Discussion 0
L Amphi Exhaust Manifold Needed General Amphicar Discussion 0
A Exhaust manifold and SU carrbs General Amphicar Discussion 3
E Unleaded Gas & Exhaust Valves General Amphicar Discussion 0
D Exhaust Seal General Amphicar Discussion 0
B Exhaust Studs General Amphicar Discussion 5
Propcar50 Need Some Guidance on Bypassing Bilge Blower General Amphicar Discussion 1
Latitude33 Bilge Pump outlet stainless steel tube General Amphicar Discussion 2
Jon March About the original bilge pump... General Amphicar Discussion 23
Jon March anybody have an extra bilge-exit "j-tube" General Amphicar Discussion 0
Jon March poll: original bilge pump mounting & depth gauge General Amphicar Discussion 1
okey0 Install of new bilge pump General Amphicar Discussion 3
azpaul50 Bilge Blower General Amphicar Discussion 2
Akamphi Bilge pump switch lamp General Amphicar Discussion 3
Akamphi Questing about ignition switch and bilge blower wiring General Amphicar Discussion 0
mike_israel Would a relay to bilge pump make sense General Amphicar Discussion 1
T Bilge Blower - How much is it worth? General Amphicar Discussion 4
CapnJohn Bilge spouts revisited... General Amphicar Discussion 1
jfriese Bilge Pump Switch Lamp General Amphicar Discussion 2
C Frame rails to bilge floor sealed? General Amphicar Discussion 2
T Bilge Blower Question ?? General Amphicar Discussion 2
sdreich Bilge Blower Timing Panel General Amphicar Discussion 4
T Chrome Bilge outlet Pipe General Amphicar Discussion 4
H amphicar bilge pump General Amphicar Discussion 7
H Bilge Pump General Amphicar Discussion 0
S Backup bilge pump: plumbing and wiring General Amphicar Discussion 9
mike_israel Bilge Blower Bypass General Amphicar Discussion 14
sdreich Bilge Blower Relays General Amphicar Discussion 3
M Bilge Pumps & Ebay General Amphicar Discussion 1
D one step away. bilge hose question Plasma/led screen question General Amphicar Discussion 1
A Bilge Plug Importance General Amphicar Discussion 1
B SV: Re: Amphicar fire gas and oil - bilge blower addition General Amphicar Discussion 2
M The sweet smell of bilge General Amphicar Discussion 0
C Celina... Ignitions... Bilge Blowers General Amphicar Discussion 12
C The Bilge..... General Amphicar Discussion 2
A Amphi B.O. ? The Battle of the Bilge General Amphicar Discussion 0
A Cornucopia in my bilge (repost) General Amphicar Discussion 0
A The World Needs Bilge Cleaners Too (Repost) General Amphicar Discussion 0
A Amphi and the battle of the bilge (Repost) General Amphicar Discussion 0
T So you like the look of your original bilge pump... General Amphicar Discussion 2
B Late Model Bilge Plug Substitution General Amphicar Discussion 1
