Gas shutoff valve(s)
rogtwo@aol.com
My car doesn't currently have any shutoff valve for the gas. I assume that
the early cars had the manual valve, and the later ones had the "magneto shut
off valve". Is this correct, or were both valves used on the same car?
Thanks
Roger St. John
Michael Echemann
Roger,
All cars had both, the shut off (fuel tap) and the magneto valve. Mike
Sent: Monday, February 10, 2003 9:13 PM
Subject: [amphicar-lovers] Gas shutoff valve(s)
Thanks
Roger St. John
THE AMPHICAR-LOVERS LIST
Bill Connelly
shut
Thanks
Roger St. John
This is how I've heard it explained: Later models had both the manual
shut-off valve and the magneto valve as stock equipment from the ealerships,
but the manual valve's famous propensity to leak if you even look at it
sideways, means that many have since been replaced with other types of taps
and (usually inline) filter arrangements by the subsequent owners. The
magnetic shutoff valve was a later addition, often a retrofitted item even
to earlier cars. It is intended to inhibit the possibility of fuel
"siphoning" down the fuel lines from the gas tank and pouring out the carb
when the vehicle was parked, especially if on an incline when the fuel level
in the tank is higher than the carb.
And that's my story...
~Bilgey~
Eric M
Mine is an early '62 (no bilge blower). It only had the manual.
Dave the Wave added the other later.
Eric
assume that
the "magneto shut
car?
> Thanks
> Roger St. John
"the manual valve's famous propensity to leak if you even look at it
> sideways"
Hello Bilgey,
Remember, I tracked down the gasket that leaks in the manual valve
(the only one that Hugh doesn't sell) and have some in stock for
whoever needs to repair that item.
alaskanamphi@gci.net
Where is this magneto shut off valve located? Is it at the carb or the fuel
pump?
What does it look like?... I'm not sure if I have one or not. I do have the
manual
valve and it works fine. :)
Craig in Alaska
Red 66
Date: Monday, February 10, 2003 6:13 pm
> assume that
> "magneto shut
> car?
> Thanks
> Roger St. John
> Archives:
> visit:
the fuel pump?
have the manual
Craig,
The fuel tap is mounted to the fitting below your tank and it will
have a "L" shaped handle that extends inside below the dash just
above and to the right of the accelerator pedal. It's Reserve/on/off.
The magneto shutof valve (12V electrically operated) is located
usually just after the fuel tap with a wire to your master cylinder
brake light switch and one to ground. Both are aluminum colored. This
one cuts the fuel when the key is off.
Re: Re: Gas shutoff valve(s)
Thanks John, I guess I don't have a magneto shut off valve. My fuel line comes
right
out of the fuel tap shut off valve. I'll have to chech and see if it is up
stream
between the tap valve and tank.
Craig in Alaska
Red 66
From: "a_colo_native <minnow@amphicar.net>" <minnow@amphicar.net>
Date: Tuesday, February 11, 2003 11:01 am
Subject: [amphicar-lovers] Re: Gas shutoff valve(s)
> or
> the fuel pump?
> do
> have the manual
> Craig,
> cylinder
> This
> John
> Archives:
> visit:
line comes right
it is up stream
> Craig in Alaska
> Red 66
Your tap is screwed directly to a left handed thread in the bottom of
your tank, so up stream *is* your tank! :) There is a pic of John
Friese's steering brace (files section) that shows the magneto valve
in the lower left corner where the bottom of his brace is bolted to.
http://autos.groups.yahoo.com/group/amphicar-lovers/files/Steering%
Thanks again John.
After looking at that pic I know now my Amphi does not have a magneto shut off
valve.
It must have been removed in the past. Sounds like something I should replace...
Craig in Alaska
Red 66
Date: Tuesday, February 11, 2003 12:34 pm
> fuel
> line comes right
> if
> it is up stream
> > Craig in Alaska
> > Red 66
> of
> valve
> to.
> Archives:
> visit:
