<table lang="EN-US" link="blue" vlink="blue" style="tab-interval:.5in">
<div class="Section1">
<p class="MsoNormal"><span class="EmailStyle18"><font size="3" color="purple" face="Times New Roman"><span style="font-size:12.0pt">Other than one defective battery
(bad cell) we?ve never seen a problem with holding a charge for several weeks
(or months), even with the clock running.<span style="mso-spacerun: yes">?
</span>We have no battery disconnect switch as previously noted.<o
></o
></span></font></span>
<p class="MsoNormal"><span class="EmailStyle18"><font size="3" color="purple" face="Times New Roman"><span style="font-size:12.0pt"><o
></o
<p class="MsoNormal"><span class="EmailStyle18"><font size="3" color="purple" face="Times New Roman"><span style="font-size:12.0pt">Check the ?interior?
light under the glove box.<span style="mso-spacerun: yes">? </span>That?s an
easy switch for the passenger to hit with a knee and may not be seen if on.<span style="mso-spacerun: yes">? </span>Not much else is ?hot? with the key
off.<span style="mso-spacerun: yes">? </span>Headlights, clock, bilge pump, and
marine lights are about it. <span style="mso-spacerun: yes">?</span>Not even brake
lights.<o
></o
<p class="MsoNormal"><span class="EmailStyle18"><font size="3" color="purple" face="Times New Roman"><span style="font-size:12.0pt">--LarryS <o
></o
></o
<p class="MsoNormal" style="margin-left:.5in"><font size="2" color="black" face="Tahoma"><span style="font-size:10.0pt;font-family:Tahoma;color:black">-----Original
Message-----
<span style="font-weight:bold">From:</span> wick68355@aol.com
[mailto:wick68355@aol.com]
<span style="font-weight:bold">Sent:</span> Friday, November 02, 2001
7:23 AM
<span style="font-weight:bold">To:</span>
amphicar-lovers@yahoogroups.com
<span style="font-weight:bold">Subject:</span> [amphicar-lovers] fuses
and dead batteries.</span></font>
<p class="MsoNormal" style="margin-left:.5in"><font size="3" face="Times New Roman"><span style="font-size:12.0pt"><o
></o
></span></font>
<p class="MsoNormal" style="margin-left:.5in"><font size="2" color="black" face="Arial"><span style="font-size:10.0pt;font-family:Arial;color:black">I
thought I would share a few thoughts about dead batteries and fuses. When
charging or jumping a battery you always hook up positive to positive and
negative to negative. Do not assume which way the car is grounded. An Amphicar
will start and run if the battery is installed the opposite way. As far
as a reason for a dead battery, something as simple as a clock or a radio can
draw a battery down to nothing. I bought my 63 Amphicar from the widow of
the original owner. He had installed a master shut off switch on the
battery terminal. I figured it was stock because I did not know any
better at the time. Well, If I forget to turn off this master switch, two
days later, bingo completely dead as a door nail. So my car will draw
down the battery too. I never went to search out why, I find it easier
just to disconnect it. I will share with you a method off checking for an
electrical draw if you are interested. Disconnect one of the battery
cables (I am not sure if it matters pos or neg) connect a 12 volt test light
between the battery and the disconnected cable. Make sure everything is in the
off position. If the light comes on you have a draw. You can track it
down by removing one of those funny German fuses one at a time until the light
goes out. Once the light goes out that circuit that you pulled the fuse from is
the culprit. As far as those fuses go I really see no reason to replace them
other they are hard to handle without wrecking the little metal strip.
There are other foreign car fuses which are the same size with the points
on both end but are glass enclosed.
Hope this helps.
Tim Wick</span></font><font color="black" face="Arial"><span style="font-family:
Arial;color:black">
</span></font><tt><font size="2" color="black" face="Courier New"><span style="font-size:10.0pt;font-family:"Courier New";color:black">To UNSUBSCRIBE
from this group, just send an email TO THE FOLLOWING ADDRESS (this is not the
same address for posting messages):</span></font></tt><font size="2" color="black" face="Courier New"><span style="font-size:10.0pt;font-family:"Courier New";
mso-fareast-font-family:"Courier New";color:black">
<tt>amphicar-lovers-unsubscribe@yahoogroups.com. </tt>
<tt>Any other issues may be addressed to the list owner/admin (Mike Israel)
amphicar770@yahoo.com</tt>
</span></font><font color="black" face="Arial"><span style="font-family:Arial;
color:black">
</span></font><tt><font size="2" color="black" face="Courier New"><span style="font-size:10.0pt;font-family:"Courier New";color:black">Your use of
Yahoo! Groups is subject to the <a href="http://docs.yahoo.com/info/terms/">Yahoo!
Terms of Service</a>.</span></font></tt><font color="black" face="Arial"><span style="font-family:Arial;color:black"> </span></br></font><font color="black"><span style="color:black;mso-color-alt:windowtext"><o
></o
></span></font>
