Fumoto Ball Valves - Coolant Lines
After thinking about the Fumoto engine oil drain valves, I realized that these
valves would make a great replacement drain valve for the heater hose line tap.
You could replace the entire "T" tap with a couple of pieces of copper pipe, a
copper "T" and one of these valves. With stainless and brass construction, these
valves should hold up to hot coolant as well as they work with hot engine oil.
