Fuel Valve Fix
Hi,
Someone asked the other day about repairing a fuel shut off valve. I
tracked down one part that usually fails and the one part that Hugh
doesn't sell. It's the seal disk that sits behind the spring clip and
valve "twist" part.
They're $10 each plus $5 shipping per order. So if you want two, it's
$25.
Contact me at jfriese(at)mindspring.com or call my cell phone at 805-
570-4778 if you want one.
Joe Biscone
that be me: joe biscone . . . also,can you ref. the assembly order (gasket, 2 spring washers, outer plate, snap ring)??? i have the valve without the 2 screws to open it . .
joe biscone,'68 white euro
Subject: [amphicar-lovers] Fuel Valve Fix
Date: Thu, 05 May 2005 04:49:55 -0000
<tt>Hi,
valve "twist" part.
$25.
</tt>
<tt>Mothers Day Flowers - Support the Amphi List
WHile the Amphicar list is provided at no charge, there is considerable time spent playing admin. Likewise, several hundred dollars have recently been spent on software and hosting for our potential move of the list. You can support these efforts by ordering flowers through one of the internets highest rated florists. Just follow the link below. It does not cost you anymore but Growers sends a couple dollars this way for each order placed via the following link.
http://www.growerflowers.com/default.asp?id=41762
THE AMPHICAR-LOVERS LIST
</tt>
___________________________________________________________
Sign-up for Ads Free at Mail.com
http://www.mail.com/?sr=signup
Hi Joe,
That order sounds about right but it's been 3 years since I've had mine
out to look at them. I believe Hugh said there were 4 variations of
the valve. I've seen 2 types and my seal disk fits both of those
correctly.
--- In amphicar-lovers@yahoogroups.com, "Joe Biscone" <princejb@c...>
wrote:
Joe Biscone
Re: Re: Fuel Valve Fix
10-4 . .
j
Subject: [amphicar-lovers] Re: Fuel Valve Fix
Date: Thu, 05 May 2005 15:59:46 -0000
<tt>Hi Joe,
correctly.
wrote:
</tt>
</tt>
10-4
D Magnetic Fuel Valve Location Question General Amphicar Discussion 6
J Fuel Reserve Valve - How to fix the leak. General Amphicar Discussion 0
S Fuel shutoff valve seals General Amphicar Discussion 3
R fuel tank valve General Amphicar Discussion 0
I Throttle Body Fuel Injection System General Amphicar Discussion 4
