echassignet
I removed the retaining ring of the fuel tap T selector (late model) to clean it up and I now have a hard time to put the retaining ring back on in such a way that the all assembly is tight. Right now, when I put it back, the ring is very loose in the groov, it does not want to remain snapped in, and the selctor moves all over the place. I presume that I made the ring out of round/shape when I removed it. Is there any trick to reshape the ring so that it can snap back in tightly? I do not want any gas leaks
Thank you in advance
Eric
Eric
