Hello all! It seems I have ran into a problem with the fuel system that I cannot solve. So here's the deal the fuel tap, inline fuel filter, fuel line, and fuel pump are brand new. The fuel pump will manually pump gas IF the fuel pump is off the block and the outlet hose is off. Once the fuel pump is on the block and outlet hose to attached to the carb, the car will idle fine. However if I proceeded to give a good amount of gas (on accelerator, off accelerator, on accelerator....and so on doing this fast) the car will starve of fuel and the pump seems to not fill the in line fuel filter. I have taken that inline filter off, used a fuel pump spacer, rebuilt the carb and none of these change anything. Anyone have any suggestions?
I'm mostly interested in the fitting part and how that works on the stock one.
