Fuel shutoff valve seals
S
Scott
I'm finally going to fix and reinstall the shutoff valve under the gas tank. I
did like many have done, turned the handle to see what happens. What happens is,
the damn things start to leak. The last time I checked there were no seals for
the valves, top o-rings and bowl seals yes, but not the seal that goes behind
the the valve face. So I'm having some made. They should be done Friday. I had
to order 10 so if anyone is interested in one or two, let me know.
Scott Moses
Kansas
gas tank. I did like many have done, turned the handle to see what
happens. What happens is, the damn things start to leak. The last
time I checked there were no seals for the valves, top o-rings and
bowl seals yes, but not the seal that goes behind the the valve face.
So I'm having some made. They should be done Friday. I had to order
Scott,
I picked up all those pats at a local Porche/Mercedes dealer. I made
my own "valve face seal" out of neoprene. I would certainly be
interested in a better one than I have.
Do you still want to hook up on the way to Celina?
John "Almost a floater" Bevins
Hi Scott,
It's not necessary to have them made. At least the one in my
Amphi was a vintage Porsche part. A local German car repair place
matched it up to my old one. When they're new, they are surprisingly
thick and get mashed down when you put the thing back together. I was
just about to go over and have him order a dozen of them in for me to
give to you guys. They're cheap too.
happens. What happens is, the damn things start to leak. The last time
I checked there were no seals for the valves, top o-rings and bowl
seals yes, but not the seal that goes behind the the valve face. So
I'm having some made. They should be done Friday. I had to order 10 so
> Scott Moses
> Kansas
S
Scott
It figures. There was talk awhile back that the parts were unavailable. I
figured I'd get the ball rolling, but if the parts are over the counter, I'm all
for that.
John, if you could get a part number for the pieces, I'd really like to get mine
put back together.
Scott Moses
Kansas
I Throttle Body Fuel Injection System General Amphicar Discussion 4
A CORRECTION TO: AMPHICAR FUEL LINES WITH FITTINGS General Amphicar Discussion 0
A Fuel lines, inside rear view mirrors General Amphicar Discussion 0
A AMPAMPHICAR FUEL LINES NOW AVAILIBLE General Amphicar Discussion 3
J Fuel Valve Fix General Amphicar Discussion 3
C Fuel line connector General Amphicar Discussion 0
