Fuel lines, inside rear view mirrors
amphiguru
Hi All,
Allan Woodcock stopped by with a sample of his fuel line. It looks
like a winner. Please note that it fits Solex 30 PSEI type
carburetors ONLY. All other Solex and Zenith carburetors have a
slightly larger fitting, identical to the fuel pump end. Our price is
$69.62. (I know, it's less than Allan's price of $75.00. Remember,
he has to make a separate box, where we put it in a box with all the
other parts ordered.)
Regarding the inside rear view mirror, just a note to let everyone
know the response to our inside mirrors has been excellent. Our price
of $39.95 remains the same.
A CORRECTION TO: AMPHICAR FUEL LINES WITH FITTINGS General Amphicar Discussion 0
A AMPAMPHICAR FUEL LINES NOW AVAILIBLE General Amphicar Discussion 3
I Throttle Body Fuel Injection System General Amphicar Discussion 4
J Fuel Valve Fix General Amphicar Discussion 3
C Fuel line connector General Amphicar Discussion 0
