Orignal sending units are zero - 180 ohm units. They are actually
only reasonable approximations of those numbers but clearly the
sending unit you're talking about using is wrong for the job on a
couple of counts. Remember, the original unit reads empty when the
reserve amount is still in the tank (assuming you're using an
original fuel shut off) and I think that is a handy feature. Unless
you're throwing out the Amphicar gauges there's no way I'd fool
around with an incorrect sending unit. If you are changing the
gauges, all bets are off.
--- In amphicar-lovers@yahoogroups.com, rogtwo@a... wrote:
> I bought a TEMPO fuel level sender a couple of months ago. Ed's
data gave me
> the push I needed to see if it would work in my Amphi. The TEMPO
sensor I
> got is labeled on the package as Part No. 280050 (Model No.
570ESU). * This
> unit, like the Stewart-Warner and Auto-Meter models, is 240 ohms
empty and 30-35
> ohms full. This is obviously not good because it has the high
resistance in
> the empty position instead of the full position.
http://www.tempoproducts.com/2004/gauges.html
> But wait! The stainless steel wire that the float is on can be
bent to
> reverse this. If you want to use one of these gauges, follow the 3
simple steps
> below.
> NOTE: The only issue with this conversion is that the fuel gauge
will not go
> quite all the way to empty. When the tank is empty, my needle goes
down to
> where it is about one needle width above the empty mark. If you
can't remember
> this when driving, then you better get a different sender.
> Here are the steps to modify the TEMPO sender (I think this sender
costs
> about $25):
> 1. Grab the stainless steel float wire about 1 inch from its pivot
point with
> two pairs of pliers. Bend the wire through 125 degrees so the
float is on
> the other side of its pivot point. Note, bending the wire through
125 degree
> will leave the wire with a 55 degree bend in it (i.e., 55 plus 125
= 180 or a
> straight wire). Now as needed, when the float is high the
resistance is high,
> and when the float is low, the resistance is low.
> 2. Slide the float and its retaining washers up the wire 1.5 inches
and then
> trim 1.5 inches off the end of the wire. Don't slide the retaining
washers up
> further than where you want them because it is difficult to get
them to move
> back the other way.
> 3. The 5 mounting holes are not evenly spaced. Thus, the sending
unit top
> can only be oriented one way on the tank. As my unit was
assembled, I could
> not install the sender in the tank because the float would hit the
front of the
> tank. But, it's easy to fix. Unscrew the nut that is on the stud
on the top
> of the sending unit. Separate the 5 holed plate from the rest of
the unit.
> Turn the 5 holed plate 90 degrees counterclockwise and reinstall
it. This will
> make the float point over toward the filler neck when the sender is
> installed. Note, the hole at the center of the 5 hole plate (its
6th hole) is square
> and matches a square plastic part on the stud. Thus, you can only
rotate the
> plate in 90 degree increments.
> This should give you a unit that reads full correctly, and goes
almost to
> empty when the tank is empty. Before installing the sender, you
might want hold
> the sender at the end of the tank and verify that the wire is bent
correctly.
> With the 5 hole plate of the sender held level at the top of the
tank, the
> float should not hang below the bottom of the tank. If you have an
ohm meter,
> you can also check that when you swing the float up level with the
top of the
> tank, that the sender has a resistance of about 180 ohms.
> * There Part No 280070 gage might be even easier to modify. You
might be
> able to just flip the little black resistor unit of this one up-
side-down.
> Roger
> White '63
> Seattle
> PS - I can e-mail before and after pictures of the sender if
someone wants.
> In a message dated 10/8/2004 6:06:45 AM Pacific Standard Time,
wb6wsn@c...
> writes:
> A short time ago, we had a thread on replacement fuel senders. Here
is some
> information that I dug out about various fuel tank sensors.
> GMC, 1964 or earlier, 0 Ohms empty to 30 Ohms full
> GMC, 1966 and later, 0 to 2 Ohms empty to 91 to 93 Ohms full
> Ford, 1987 & later, 16 Ohms empty to158 Ohms full
> Ford, pre-1987, 73 Ohms empty to 10 Ohms full
> AMC, 73 Ohms empty to 10 Ohms full
> Toyota, 1985 & later, 90 Ohms empty to 0 Ohms full
> Nissan, 1985 & later, 90 Ohms empty to 0 Ohms full
> Stewart-Warner, 244 to 250 Ohms empty to 29 to 33 Ohms full
> Auto-Meter, 240 Ohms empty to 33 Ohms full
> Amphicar, 10 Ohms empty to 180 Ohms full
> This isn't exactly everything that's available; it just shows you
that there
> isn't any "universal" fuel tank sender unit. If you replace the
Amphi with
> "something else", you can get weird results. You have to remember
to match
> the sender's resistance curve to the gauge's response curve.
> Ed
> El Cajon, CA USA
> 67 Rust Guppy
> [Non-text portions of this message have been removed]
