tcamphicar
Ordered front wheel bearing and seals from EB Atmus.
Timken Bearings and (abbreviated) Harwl seals. Good prices
and delivery. http://www.ebatmus.com
The RF hub came off without a puller which did not seam right. It
basically fell off! Do I have another problem?
I removed the races and put in the new ones on the RF with no
problem.
PROBLEM: Before I removed the old seal I could see that it was
damaged. The rubber was uneven on one side (looked bound
up) and someone had put silicon all around where the seal
seats. The problem I am having is installing the new seal. I
ruined one trying to install it. It wouldn't go in all the way. I used
a block of wood & hammer to tap evenly but it bound up. I took
out the one I ruined and rechecked the casting the seals fits into
and it seems fine.
I just checked the Amphicar Technical page and it has two seal
numbers listed. I bought the one's with the last 2 numbers
being "10" and mine has a "B" at the end. The page also shows
"08". Would the one's with the "8" be smaller? Maybe mine are
to large?
I not sure what to do at this point. I slightly put another new seal
on that I was going to use on the other side but want to make
sure it will fit before I force it and possibly ruin it too! Any
suggestions?
This is what the Amphicar Technical page shows:
FRONT WHEEL BEARING SEAL - 68X85X10 (CR) 26630
68X85X08
Thanks for your thoughts,
Captain Terry
MY ORDER:
2ea 30206 tapered roller bearing (inner)
2ea 30204 tapered roller bearing (outer)
2ea 68x85x10B Metric Seal
problem.
and it seems fine.
to large?
suggestions?
68X85X08
Captain Terry
MY ORDER:
