Front wheel bearing seal
avbell2
I'm changing the front wheel bearings on my "new" red '66. Under the
metal cup that covers the end of the axle is an O-ring. I was told
that there should not be an O-ring in the groove but there is
definitely one there now. Replace it with a new one or toss it out
entirely? I see where this question came up before on the forum but I
can't see where anyone answered it.
Mike Bell
Red '66
Sacramento, CA
Although it looks like it's for an O ring that grove is to hold the rubber cap
that was fitted to very early Amphicars. The idea being the rubber would
compress slightly and you wouldn't have a problem of water being sucked in to
the wheel bearings. When using the metal cup you need a seal isn't quite
air-tight. That way if there is a pressure difference any water gets sucked
inside the metal cap (where it doesn't cause a problem), instead of past the
inner oil seal where it does. So, in short, remove the O ring.
avbell2
Well that settles that, and saves me from trying to find new O-rings.
Thank you Mr.Chapman.
rubber cap
would
sucked in to
quite
gets sucked
past the
> David Chapman
T Front wheel bearing removal? General Amphicar Discussion 5
A Front wheel bearing #s General Amphicar Discussion 1
S Front wheel bearing grease tool General Amphicar Discussion 0
D Front wheel bearing adjustment General Amphicar Discussion 0
B SV: Shocks/Front Wheel General Amphicar Discussion 0
M Shocks/Front Wheel General Amphicar Discussion 1
R Front wheel question General Amphicar Discussion 5
E Front Wheel Grease Seal General Amphicar Discussion 0
A Front Wheel Cylinder General Amphicar Discussion 4
E Stuck front wheel General Amphicar Discussion 1
S Front Wheel Lock General Amphicar Discussion 0
W front wheel bearings General Amphicar Discussion 3
F Front bumper General Amphicar Discussion 2
