Front wheel bearing grease tool
S
scott
I made a tool today to grease the inside front wheel bearing. I took a simple
spray paint can plastic top, cut a hole in the center for the axle stub to fit
through, and put a grease sert on the top toward the outer edge.
I could not believe how well it worked. It fit perfectly around the outside of
the bearing and the center raised section fit perfectly around the inside. I can
post pictures if anyone need them.
Scott Moses
Kansas.
