Front Suspension/Steering Adjustment???
Tedredamphi
I just replaced all of the tie rod ends on my front steering and can't seem to find any adjusting measurements in the manual for the short rods called track rods or connecting rods (#5-21-50). Have a picture of one below.
Any help would be greatly appreciated.
Ted Matthews
I also replaced the rubber boot(7-25-03) at bottom of steering gearbox with one of Gordon Imports new reproductions. It fit just like the original - thanks Hugh!!
Found an old track rod in my parts box and it measures about 7-1/8" from center to center. Does that sound about right?
Ted
E Front Suspension Spring Rate General Amphicar Discussion 2
F Front bumper General Amphicar Discussion 2
auburnamphi Rechromeing Front Bumpers General Amphicar Discussion 6
B front shocks General Amphicar Discussion 10
T Front Bumper Bracket Mounting??? General Amphicar Discussion 4
T Amphicar Makes front page of Fort Worth Star-Telegram General Amphicar Discussion 2
T Front Bumper Brackets General Amphicar Discussion 10
A Front bumper bolts General Amphicar Discussion 1
