front shocks
what after market shocks will fit on my 63 amphi Bryant Speedway In
Hello,
NONE. Certainly none that I would try. Get the shocks that Gordon's had made. They are safe and work fine.
Canadian four amphs
You are wrong! John.
Kimpex # 04-262 fronts amphicar 62-4
These are gas charged and very powerfull so with Original springs are too stiff. they have an ajustable colar on them and cost well under $100 each
You need to have a lighter spring as well. I have used Kimpex skidoo springs in my 62 and am quite happy with the ride.
You will meed to reuse the bushings out of you old shocks or get new ones made up at spring shops.
GORD
Candaian 4 amphs
Gord : I take it that the Kimpexs shocks can not be used on a 1967 amphi.
Thanks Paul NY
To: pvcj@hotmail.comSubject: RE: [General Amphicar Discussion-t-20076] Re: front shocksDate: Tue, 8 Jul 2008 08:49:46 -0400From:
You are wrong! John.Kimpex # 04-262 fronts amphicar 62-4These are gas charged and very powerfull so with Original springs are too stiff. they have an ajustable colar on them and cost well under $100 eachYou need to have a lighter spring as well. I have used Kimpex skidoo springs in my 62 and am quite happy with the ride.You will meed to reuse the bushings out of you old shocks or get new ones made up at spring shops.GORDCandaian 4 amphs
Making the world a better place one message at a time.
http://www.imtalkathon.com/?source=EML_WLH_Talkathon_BetterPlace
Canadian four amphs
on 65-7 front they go threw the body..
I have found a kimpex with a long shaft, have cut the head off and treaded the shaft, again reusing the parts off old shock have made them work with great ride, but is alot of work,
numbers are 04-258 or 08-295 0r 08- 296.
rears 04 268 with tread all the way to bottom or no good,
front spring.. 04-295 or6 will give good ride on 62-4 cars
GORD
DrNoose
FWIW, I have been very pleased with the shocks I got from Hugh. I think
they were worth every penny. These suckers look like they were built to
last forever, and so far so good! Rebuildable too! Das Boot has seemed
pleased with them as well. :^)
Dan
'64 Das Boot
LSolheim
Paul, several years ago I fabricated adapter mounts to allow the use of early model thru-bolt shocks on the late model cars with the thru-hull bayonet style mounts. If you would like an Autocad drawing or a .jpg copy, please let me know. It's an easy build.
I ran the Surplus Center MAECO shocks (snowmobile shocks) for 4 years and they worked great, even with 10,000+ towing miles on them.
--Larry
Larry : That whould be great, i don,t have alot of money to buy the ones that Hugh sells.
paying for two collage loans:) If i did not do all the work myself i whould not have an amphi
today. Thanks PAUL 67amphi From NY
To: pvcj@hotmail.comSubject: RE: [General Amphicar Discussion-t-20076] Re: front shocksDate: Wed, 9 Jul 2008 00:01:49 -0400From:
Paul, several years ago I fabricated adapter mounts to allow the use of early model thru-bolt shocks on the late model cars with the thru-hull bayonet style mounts. If you would like an Autocad drawing or a .jpg copy, please let me know. It's an easy build.I ran the Surplus Center MAECO shocks (snowmobile shocks) for 4 years and they worked great, even with 10,000+ towing miles on them.--Larry
Thanks Gord:
To: pvcj@hotmail.comSubject: RE: [General Amphicar Discussion-t-20076] Re: front shocksDate: Tue, 8 Jul 2008 20:06:13 -0400From:
on 65-7 front they go threw the body..I have found a kimpex with a long shaft, have cut the head off and treaded the shaft, again reusing the parts off old shock have made them work with great ride, but is alot of work,numbers are 04-258 or 08-295 0r 08- 296.rears 04 268 with tread all the way to bottom or no good,front spring.. 04-295 or6 will give good ride on 62-4 carsGORD
It’s a talkathon – but it’s not just talk.
http://www.imtalkathon.com/?source=EML_WLH_Talkathon_JustTalk
Gord: Can you still get these shocks, And if so how much?? I just can,t spend $1,000.00 dollars
on shocks right now. It has nothing to do with the quality of Hughs shocks? just don,t have the money. Thanks Paul From NY
Need to know now? Get instant answers with Windows Live Messenger.
http://www.windowslive.com/messenger/connect_your_way.html?ocid=TXT_TAGLM_WL_messenger_072008
Canadian four amphs
IN CANADA THERE CALLED (www.ROYAL DISTRIBUTING.com)
there is probaly similar dealers in USA. where they sell Kimpex.
doing a friend Ampi right now
4 for 400 plus time is better than $1000
M Aldan Front Shocks For Amphi General Amphicar Discussion 10
B SV: Shocks/Front Wheel General Amphicar Discussion 0
M Shocks/Front Wheel General Amphicar Discussion 1
S NOS Front Shocks General Amphicar Discussion 0
W front shocks General Amphicar Discussion 4
T Front Suspension/Steering Adjustment??? General Amphicar Discussion 0
auburnamphi Rechromeing Front Bumpers General Amphicar Discussion 6
T Front Bumper Bracket Mounting??? General Amphicar Discussion 4
T Amphicar Makes front page of Fort Worth Star-Telegram General Amphicar Discussion 2
T Front Bumper Brackets General Amphicar Discussion 10
A Front bumper bolts General Amphicar Discussion 1
