To better seal the front edge of the door (other than adding a rubber "shim" under the door seal effectively moving it closer to the body), is there any hinge adjustment for the leading edge of the door?
To better the the front edge of the door o(ther than adding a rubber "shim" under the door seal effectively moving it closer to the body), is there any hinge adjustment for the leading edge of the door?
In extreme cases after removing the glass, I have had to use hydraulic power tools and long levers to bend the hinges to fine tune the fit and gaps. I had to twist the entire door shell to make it just right. It's not for the faint of heart!
